Hello friends, I m a new user with little knowledge to play with mini2440. I have a mini2440 with 64MB NAND flash. I want to set qt environment on it. (either with qtopia or opie) I have my own OpenEmbedded environment with bitbake ,etc. toolchains set. Got from here: (http://code.google.com/p/mini2440/wiki/OpenEmbedded) I created console-image , trolltech-qtopia-core-gui-image-mini2440 , qt4-image-mini2440 and opie-image successfully in my openembedded environment , with all their jffs2 and etx3 files. My kernel is -> uImage-2.6.31+git-r9-mini2440.bin But when I NAND flash my jffs2 file system (any of qt4i-mage-mini2440,trolltech-qtopia-core-gui or opie image), i can't get display on mini2440. I only get a console login for it. For NAND flashing , i followed the instructions mentioned here: (http://narnia.cs.ttu.edu/drupal/node/131) Also, when I set kernel parameters to tell mini2440 to take SD card as filesystem drive, it refuses to read from SD card, but for NAND flashing it can COPY my jffs2 files from SD card successfully. Here is an output when flashing opie-image on mini2440:(http://pastebin.com/m7cdffa73) Here is output when flashing trolltech-qtopia-core-gui on mini2440:(http://pastebin.com/m106e8671) Plz help me................
Problem with NAND flashing qt image on mini2440
I have same problem with OpenEmbedded images like x11-gpe-image with 7" MINI2440: after power-on LCD stays white and has some random vertical stripes. Only serial port gets console output. If I restore the backupped factory Qtopia image to the NAND then it works again, so it's not a DC power issue. I'm using uboot and kernel 2.6.31 from repo.or.cz mini2440.git repository. Do I need to enable the LCD display output by writing to some node in /dev or /sys filesystem during init?
