Partition NAND Flash memory...
svprem 2010-07-27 11:42:38 Link
Dear all,
         I am trying to Port zImage to Mini2440..There is some problem in
my compilation booting the image. I am using the supervivi bootloader to
boot from Flash memory. File System is not booted correctly. While
searching for error i found that NO MTD PARTITION on NAND is being created,
showing the error,
cmdlinepart partition parsing not available
noinitrd root=/dev/mtdblock2 init=/linux console=ttySAC0
no such root...
I have checked out the configuration where i have also enabled MTDPARTS,
USBSUPPORT.. i dont know where i am going wrong.. Any ideas would be
helpful....waiting for any suggestions.....
andreo 2010-07-31 10:13:03 Link
partioning in supervivi:
q => commandline
help => get commands
part add/new/del => operate partions
something anormal is, you can not create a partion between other partions.
also like FIFO
Reply
Name
eMail (not visible)
Text
Please enter the number 2440
