Hi i am using mini2440 with wince5.0 i want to use TPlink TL-WN321G+ for wireless lan. can anybody have the driver for tplink for wince..???
Mini2440 tplink driver for WinCE need help...
I use this for same adapter : http://driverscollection.com/?aid=4001823787533f6a92f52b7ec72 You only need these two files : RT2501USB.dll and rt2501usb.reg Regards!
I used "CEFileWiz.exe" in order to insert "RT2501USB.dll" into my image.In platform builder I inserted my existing project and I copied "rt2501usb.reg" into "myDriver.reg". But when I "build current project", I obtain this error: Error: Unknown memory type found 'Memory' Name Path Memory Type Error: failed setting line makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec). makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec). Can you help me?
Now I risolved this error, but when I insert my usb-wifi-pen I don't see any change or request by winCE
Hi Gianni, Download the files RT2501USB.dll and rt2501usb.reg from the following link http://driverscollection.com/?aid=4001823787533f6a92f52b7ec72 Go to folder C:\WINCE500\PLATFORM\smdk2440\FILES and copy the file "RT2501USB.dll" Now open platfrom builder In platform builder you can see on the Left side the OS design view Click on the Parameter view tab below it.. now click the plus sign in smdk2440 you can see different files 1-hardware specific files 2-Project specific files expand both.. double click platform.reg file inside hardware specific files and Add the contents of rt2501usb.reg in the end of the files (bottom of file) repeat this process for Project.reg inside the Project specific files. Now double Click Project.bib inside Project specific files and Add the following line(without Quotes) just above the FILES heading "RT2501USB.dll $(_FLATRELEASEDIR)\RT2501USB.dll NK SH" (NOTE: This is one line) Now repeat this process for Platform.bib in the Hardware specific files add the line just above the FILES heading.. Now build the image.. I did it for TPLINK TL-WIN321 G+ USB wifi device and it works fine.. Hope it Helps.. Thanks and Regards Hussain Aftab
