hi im tring to make an application for my mini using qt for doing this i have making this steps: 1-im using tslib-1.0 adn qt-everywhere-opensource-src-4.6.2 packages 2- this its how i could cross compile this tslib without mistakes: /***********************************************/ export ac_cv_func_malloc_0_nonnull=yes ./configure --build=i386-linux --host=arm-linux --target=arm-linux \ --disable-inoutapi --prefix=/usr/local/Qt/tslib make make install /*********************************************/ 3- i configure this files of the packages qt-every .... File: mkspecs/qws/linux-arm-g++/qmake.conf this its my file: /*************************************************/ # qmake configuration for building with arm-linux-g++ include(../../common/g++.conf) include(../../common/linux.conf) include(../../common/qws.conf) # modifications to g++.conf QMAKE_CC = /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-gcc -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0 QMAKE_CXX = /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-g++ -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0 QMAKE_LINK = /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-g++ -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0 QMAKE_LINK_SHLIB = /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-g++ -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0 # modifications to linux.conf QMAKE_AR = /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-ar cqs QMAKE_OBJCOPY = /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-objcopy QMAKE_STRIP = /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-strip load(qt_config) /******************************************************************/ file: mkspecs/common/g++.conf QMAKE_CFLAGS_RELEASE += -O0 /***************************************************************/ 4. after i did this changes i compile qt-every ... with the following command lines: ./configure -release -embedded arm -xplatform qws/linux-arm-g++ -prefix \ /usr/local/Qt -qt-mouse-tslib -L /usr/local/tslib/lib -I /usr/local/tslib/include -little-endian -no-webkit \ -no-qt3support -no-cups -no-largefile -optimized-qmake \ -no-openssl -nomake tools it compiles without mistakes. /***************************************************************/ 5.after this i copy some examples to my usb from examples folder (the folder who was created when it compiled) 6. i copy the lib folder (the one who was made when i compile qt-every ... and also libts-0.0.so.0) to my usb 7. on my mini2440 console wrote this configuration: export TSLIB_TSEVENTTYPE=INPUT export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_TSDEVICE=/usr/input/ts export TSLIB_CALIBFILE=/usr/etc/pointercal export TSLIB_CONFFILE=/usr/etc/ts.conf export TSLIB_PLUGINDIR=/usr/lib/ts export LD_LIBRARY_PATH=/udisk/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=tslib:/usr/input/ts export QWS_DISPLAY=LinuxFB:mmWidth=310:mmHeight=190 8. finally i wrote the command line: ./tetrix -qws but appearsme this mistake: ILLEGAL INSTRUTION WHAT IM DOING WRONG??? HELPP THIS ITS MAKING ME CRAZY!!! thanks!
problems making qt aplications
hey, what about to compile tslib with "-msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0" or somethink like this? i compiled with ./configure CC=arm-none-linux-gnueabi-gcc CFLAGS="-O0 -march=armv4 -mtune=arm920t -pipe" CXX="arm-none-linux-gnueabi-g++ -O0 -march=armv4 -mtune=arm920t -pipe" -host=arm-none-linux-gnueabi -target=arm-none-linux-gnueabi -enable-static=no -enable-shared=yes -prefix /usr/local/tslib
