ok so here's the arm_qtopia,
which is important of the two. I would rather have arm_qtopia (downloaded
from friendlyarm.net) working than x86_qtopia.
configuration ubuntu 10.4, toolchain installed. and also was able to build
the kernel from the DVD.
now i'm really stuck. arm_qtopia isn't working.
please help. i would really be grateful. TIA
see the attached file for complete build logs.
********* Build Qtopia ************
QPE_CFG="'edition' 'pda' '-displaysize' '240x320' '-fontfamilies'
'helvetica fixed micro smallsmooth smoothtimes unifont' '-luuid'
-no-qtopiadesktop -release -platform 'linux-g++' -xplatform
'linux-arm-g++'"
WARNING: defaultbuttons-arm.conf does not exist.
The following configuration values have been guessed or autodetected:
-arch arm
-edition pda
-fontsizes all
-fontstyles 50 50i 75 75i
-languages en_US
Symlinking header files to include directory
Creating qmake...No makedepend available
make[1]: Entering directory
`/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/qmake'
..............................................make[1]: Leaving directory
Creating pngscale...make[1]: Entering directory
`/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/util/pngsc
ale'
.................................................................make[1]:
*** [../../bin/pngscale] Error 1
ale'
Failed to make pngscale
* ERROR: Building Qtopia has failed.
* Please search the make output for any error messages.
* Hint: If the configuration has changed since the last successfull
* build consider using make clean to ensure that all binaries
* are rebuilt using the new configuration.
* For more information about the build process please use a browser
* and go to the getting started section in:
/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/doc/html/in
dex.html
/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/scripts/bui
ldQtopia
-build qpe
Qtopia Tools exist.
arm_qtopia : also fails
Ok so i was able to make some progress. it's building right now... will have to wait and see. but looking through the logs here's what i see /usr/local/arm/4.3.2/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.2/../../../../arm -none-linux-gnueabi/bin/ld: warning: library search path "/usr/X11R6/lib" is unsafe for cross-compilation make[1]: Leaving directory `/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qt2/src' Any idea what's going on. I followed the advice give here http://www.friendlyarm.net/forum/topic/332 i made those changes added lib uuid and the build going ok so far.. but can someone explain what that above message means. "unsafe for cross-compilation" should i change the LD_LIBRARY_PATH to something ? if yes that what should it be ? after i'm done i'll write a post with the steps to build qt2 on ubuntu 10.4(LTS) thanks in advance.
oh it just finished building. apparently while linking konqueror it complains about "/usr/lib/libjpeg.so: could not read symbols: File in wrong format" also why is it using -L/usr/local/kde/lib that first i don't have kde and second why use host files should this point to somewhere else ?? PLEASE someone help. i'm getting close. here's the whole error message.. i'm also attaching the complete build log file. /opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/include/qto pia/../../src/libraries/qtopia/applicationinterface.h:49: warning: 'struct ApplicationInterface' has virtual functions and accessible non-virtual destructor In file included from mainwindebug.cc:26: ./../dropin/kmessagebox.h:76: warning: unused parameter 'okButton' /bin/sh ../../libtool --silent --mode=link --tag=CXX arm-linux-g++ -Wnon-virtual-dtor -Wno-long-long -Wundef -Wall -W -Wpointer-arith -Wmissing-prototypes -Wwrite-strings -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -DNDEBUG -DNO_DEBUG -O2 -fno-exceptions -fno-check-new -fno-rtti -D_QT_QPE_ -DQT_CLEAN_NAMESPACE -DQT_NO_COMPAT -DQT_NO_ASCII_CAST -ldl -o konqueror -L/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/lib -L/usr/local/kde/lib main.o mainwindowbase.o htmlview.o popuphandler.o view.o run.o browseriface.o bookmarks.o preferences.o preferencesimpl.o mainwindow_qpe.o mainwindow_x11.o mainwindow_kiosk.o xmltree.o bookmarkeditor.o bookmarkeditorimpl.o bookmarkedit.o bookmarkeditimpl.o mainwindebug.o ../../konq-embed/kdesrc/khtml/ecma/libkjs_html_i.la ../../konq-embed/kdesrc/kjs/libkjs.la ../../konq-embed/kdesrc/khtml/libkhtml_i.la /usr/lib/libjpeg.so: could not read symbols: File in wrong format collect2: ld returned 1 exit status make[5]: *** [konqueror] Error 1 make[5]: Leaving directory `/opt/FriendlyARM/mini2440/arm-qtopia/konq/konq-embed/src' make[4]: *** [all-recursive] Error 1 make[4]: Leaving directory `/opt/FriendlyARM/mini2440/arm-qtopia/konq/konq-embed/src' make[3]: *** [all] Error 2 make[3]: Leaving directory `/opt/FriendlyARM/mini2440/arm-qtopia/konq/konq-embed/src' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/opt/FriendlyARM/mini2440/arm-qtopia/konq/konq-embed' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/opt/FriendlyARM/mini2440/arm-qtopia/konq' make: *** [all] Error 2 arm-linux-strip: 'konq-embed/src/konqueror': No such file opt/Qtopia/lib/fonts/ opt/Qtopia/lib/fonts/helvetica_120_50.qpf opt/Qtopia/lib/fonts/songti_160_50.qpf opt/Qtopia/lib/fonts/fontdir opt/Qtopia/lib/fonts/helvetica_120_50_t5.qpf cp: cannot stat `konq/konq-embed/src/konqueror': No such file or directory
/usr/lib/libjpeg.so: could not read symbols: File in wrong format I have the problem too。How about yours now? I didn't solve it. Can you tell me?
/usr/lib/libjpeg.so: could not read symbols: File in wrong format I also have the problem . I didn't solve it now . How about yours now? Can you tell me?
