Hi, i'm trying to get the x86_qtopia (downloaded friendlyarm.net) and copied under /opt/FriendlyARM/mini2440/x86-qtopia but after calling build-all here's the output i see. I'm stuck. please help... backend/vcc_yacc.cpp:38: warning: ‘yyrcsid’ defined but not used g++ -c -pipe -DQWS -fno-exceptions -fno-rtti -Wall -W -Os -fPIC -DQTOPIA_DATA_LINKING -DQCONFIG=\"qconfig-qpe.h\" -DQTOPIA_TARGET=\"qpe\" -DQTOPIA_TRTARGET=\"libqpe\" -DQT_NO_DEBUG -I/opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/mkspecs/q ws/linux-generic-g++ -I. -I../../../include/qtopia/private -I../../../pics/qpe -I../../../include -I/opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qt2/include -I../../../include/qtopia/private/ -I.moc/release-shared/ -o .obj/release-shared/vobject.o backend/vobject.cpp backend/vobject.cpp: In function ‘VObject* addGroup(VObject*, const char*)’: backend/vobject.cpp:419: error: invalid conversion from ‘const char*’ to ‘char*’ backend/vobject.cpp: In function ‘void writeEncString(OFile*, const char*, bool)’: backend/vobject.cpp:1111: warning: suggest parentheses around ‘&&’ within ‘||’ backend/vobject.cpp: In function ‘bool includesUnprintable(VObject*, bool)’: backend/vobject.cpp:1168: warning: suggest parentheses around ‘&&’ within ‘||’ backend/vobject.cpp:1169: warning: suggest parentheses around ‘&&’ within ‘||’ make[5]: *** [.obj/release-shared/vobject.o] Error 1 make[5]: Leaving directory `/opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/src/librar ies/qtopia' make[4]: *** [all] Error 2 make[4]: Leaving directory `/opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/src/librar ies/qtopia' make[3]: *** [sub-libraries-qtopia] Error 2 make[3]: Leaving directory `/opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/src' make[2]: *** [all] Error 2 make[2]: Leaving directory `/opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/src' make[1]: *** [all] Error 2 make[1]: Leaving directory `/opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia' *********************************************************************** * * ERROR: Building Qtopia has failed. * * Please search the make output for any error messages. * * Hint: If the configuration has changed since the last successfull * build consider using make clean to ensure that all binaries * are rebuilt using the new configuration. * * For more information about the build process please use a browser * and go to the getting started section in: * /opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/doc/html/in dex.html * *********************************************************************** /opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/scripts/bui ldQtopia -build qpe install Qtopia Tools exist.
