Hello, Anyone knows how to calibrate the stylus before building the image? When I compile the image I'm getting random settings from the stylus and I would love to have it set from the start! Thanks in advance!
calibrating the stylus from withing the image
Hi wanderer, Could you please describe what kind of image you talk about? For example if you use linux and tslib then you can calibrate touchscreen (not stylus :) ) using ts_calibrate utility.
Hello mgalemin , I'm using windows ce as a platform to develop a program for a school project. My problem is that I want to load as less resources as possible so my program has more ram available. That's why I want to calibrate it from Platform Builder if possible so I don't have to load windows and calibrate the touch panel via control panel. Any suggestions/ideas? Thanks!
