Hi all, i was wondering if there's any way to get the board working on the highest frequency 533Mhz as stated in the S3c2440A data-sheet ,as i thought it would be adjusting the pll.but after going through the source files of the Pll and the clock in mach-s3c2440 ,,I found that these files are just stick into th 400Mhx only ???? So will I adjusting the source files in the devisors and the upll and these stuff ??? is it the way for that or there's another way ? Appreciate your time Thanks
Getting the peak frequncy 533
It seems most of these CPUs are not qualified to run at 533 MHz. On the other hand you must consider your SDRAM is able to run at 133 MHz, because the CPU clock and the SDRAM clock are coupled.
Hello Juergen, I am able to increase freq. upto 420 Mhz and board are running perfectly fine, but if i try to increase freq. above 420 (let's say 423) it gives me random char at boot time and also when i try to repeat same command on command line via up arrow. can someone please let me know what is the max. freq. mini2440 board operates very well without any problem at OS side. From my end it is 420 Mhz max. with kernel 2.32.2. Thanks for your help in advance -- freq.
Hi freq, I think these random characters come from an incorrect baud rate. The baudrate frequency is generated from the main frequency devided by a factor. It seems that the combination main freq and divider cannot give a correct baudrate. Try a lower baudrate. It is possible that by increasing your frequency it runs perfectly again. Luc.
BusError experimented with the frequencies and which ones will work with video and RAM timing and all that. I would check his blogs.
Hello Luc, Thanks for the reply, I will check the baud rate and will try again and let u know the result. One more question, If i run the board on 450 Mhz freq. will that affects the board, I want to run this board in industry environment when machine used to run 24x7. does any one encounter the problem of running board with higher freq and board acts weirdly. -- freq.
