Hello Dear All, Is it possible to use a usb hub with mini2440 which runs armstrong linux? Kind Regards
Using a USB Hub
Using Debian with a USB Hub, no problems. (Cam and Wifi) Think linux "version" might not be relevant here. Use a PSU if you need power from the port
Dear Peter, I want to connect a cam and a wifi adapter. Hearing there is no problem with it is wonderful. Thank you! Kind Regards
