Hi, we want to use the Mini2440 with the gadget g_serial . We configure it with the downloaded sources 2.6.32.2-mini2440_20100113. When booting in NOR in supervivi, the Mini2440 is recognized by the host. Then I press [b] to boot the image, and the Mini2440 is recognized as a serial gadget. It's the correct way. But, when booting directly in NAND, the gadget is mounted by the kernel without any error (/dev/ttyGS0 exists) and the host PC never see anything connected. What is missing in my kernel that is done by supervivi ? Thanks Michel
gadget g_serial on mini2440SDK and kernel 2.6.32
I'm pulling my hair out over the same problem. Let me know if you have any
progress.
My analysis so far: It seems like the low-level UDC driver isn't setting up
the device right. For instance, when I boot through supervivi:
[root@forehead0 /]# cat /sys/kernel/debug/s3c2410_udc/registers
FUNC_ADDR_REG : 0x000D
PWR_REG : 0x0000
EP_INT_REG : 0x0000
USB_INT_REG : 0x0000
EP_INT_EN_REG : 0x001F
USB_INT_EN_REG : 0x0004
EP0_CSR : 0x0000
EP1_I_CSR1 : 0x0000
EP1_I_CSR2 : 0x0030
EP1_O_CSR1 : 0x0000
EP1_O_CSR2 : 0x0030
EP2_I_CSR1 : 0x0000
EP2_I_CSR2 : 0x0010
EP2_O_CSR1 : 0x0000
EP2_O_CSR2 : 0x0010
but when I boot directly from nand:
FUNC_ADDR_REG : 0x0000
PWR_REG : 0x0008
EP_INT_REG : 0x0000
EP_INT_EN_REG : 0x0001
USB_INT_EN_REG : 0x0005
EP0_CSR : 0x0000
EP1_I_CSR1 : 0x0000
EP1_I_CSR2 : 0x0020
EP1_O_CSR1 : 0x0000
EP1_O_CSR2 : 0x0020
EP2_I_CSR1 : 0x0000
EP2_I_CSR2 : 0x0020
EP2_O_CSR1 : 0x0000
EP2_O_CSR2 : 0x0020
Note the bit PWR_REG&0x08, which indicates the USB device interface is
receiving reset.
Aha, the problem is that there is a pullup resistor on the USB line which
is supported for many boards, but not by the drivers for the mini2440. Here
is a patch that seems like the right way of fixing it:
Index: linux/arch/arm/mach-s3c2440/mach-mini2440.c
--- linux/arch/arm/mach-s3c2440/mach-mini2440.c (revision 5)
+++ linux/arch/arm/mach-s3c2440/mach-mini2440.c (working copy)
@@ -66,6 +66,7 @@
#include <plat/nand.h>
#include <plat/pm.h>
#include <plat/mci.h>
+#include <plat/udc.h>
#include <sound/s3c24xx_uda134x.h>
@@ -290,6 +291,34 @@
.ignore_unset_ecc = 1,
+ Enable the pullup resistor for the device-side ("gadget") USB port.
According to the
+ Microarmsystems.com schematic there is a 1.5k resistor (R29) between
GPC5 and the D+
+ line of the USB.
+static void mini2440_udc_pullup(enum s3c2410_udc_cmd_e cmd)
+ switch (cmd) {
+ case S3C2410_UDC_P_ENABLE :
+ printk(KERN_INFO "mini2440_udc_pullup enable\n");
+ s3c2410_gpio_setpin(S3C2410_GPC(5), 1);
+ break;
+ case S3C2410_UDC_P_DISABLE :
+ printk(KERN_INFO "mini2440_udc_pullup disable\n");
+ s3c2410_gpio_setpin(S3C2410_GPC(5), 0);
+ break;
+ case S3C2410_UDC_P_RESET :
+ printk(KERN_INFO "mini2440_udc_pullup reset\n");
+ break;
+ default:
+ break;
+static struct s3c2410_udc_mach_info mini2440_udc_cfg __initdata = {
+ .udc_command = mini2440_udc_pullup,
/* DM9000AEP 10/100 ethernet controller */
#define MACH_MINI2440_DM9K_BASE (S3C2410_CS4 + 0x300)
@@ -369,8 +398,13 @@
#endif
s3c_i2c0_set_platdata(NULL);
+ s3c24xx_udc_set_platdata(&mini2440_udc_cfg);
s3c2410_gpio_cfgpin(S3C2410_GPC(0), S3C2410_GPC0_LEND);
+ /* pullup for usb device (gadget) port */
+ s3c2410_gpio_cfgpin(S3C2410_GPC(5), S3C2410_GPIO_OUTPUT);
s3c_device_nand.dev.platform_data = &friendly_arm_nand_info;
s3c_device_sdi.dev.platform_data = &mini2440_mmc_cfg;
platform_add_devices(mini2440_devices, ARRAY_SIZE(mini2440_devices));
Hi Trevor, I found there were a power problem but not enough knowledge to solve it. I applied your patch, and now the serial port is mounted in a nand boot process. Thanks
