Hello, after developping my first test application ( thanks for domodom for all the tutorial ), i would like to go further with my mini2440. My goal is to use the without LCD/TS because it's a real embedded application. so i would like to remove all the LCD drivers, and just communicate eventually with a serial com. Is it possible with Windows CE ? how to do ? Thank you for your help Fred
WinCE working without LCD/TSLIB
Hello Fred, With a ethernet cable, you can use FTP to upload/download file to/from the mini2440, and Telnet to obtain access to a console (like the DOS like console you have when you lauch cmd.exe). If you don't need to update your nk.bin, i think it could be enough. Best regards Domodom
Hi, WinCE is designed to be completely embedded. But that will complicate things. Your app will probably have to be a console app, and you will have to auto start it. I don't think the usual auto start will work as that is done by the GUI, I think. If i remember correctly then you can shrink the image to around 5MB if you rip out all the GUI stuff, but don't quote me on that, I looked at that MANY years ago. But there should be help files with WinCE for headless setups... Thanks, Errol
These don't say much, but might help: http://msdn.microsoft.com/en-us/library/ms404357(VS.90).aspx http://msdn.microsoft.com/en-us/library/aa459152.aspx This I can't read at the moment as i can't access FTP sites: ftp://ftp.dmp.com.tw/vortex86dx/wince/WinCE_Headless.pdf Thanks, Errol
Hi Domodom and Errol, thank you for your answer, i will try this as soon as possible. TFTP seems a good way to explore thank you again ! Fred
