hi all I have a micro2440 with 128 MB of NAND flash. I am compiling busybox 1.13.3 using make ARCH=armCROSS_COMPILE=armlinux- but while compiling it is giving an error like Trying libraries: crypt m Library crypt is not needed, excluding it Library m is needed, can't exclude it (yet) Final link with: What will be the reason for this.
problem with Busybox
Compile Busybox I started by compiling Busybox as static. When things are working properly you may want to re-compile as dynamic. [busybox-1.13.3] # make defconfig [busybox-1.13.3] # make ARCH=arm menuconfig [busybox-1.13.3] # make clean [busybox-1.13.3] # make ARCH=arm [busybox-1.13.3] # make ARCH=arm CONFIG_PREFIX=/home/user/mini2440-bootstrap/target install Try that and tells me where it "falls-over".
