I'm a new user of the Mini2440, and set up my environment based on the lovely post at: http://equallybad.blogspot.com/2010/02/project-how-to-setup-default-dev-... However when I run the ./run-hello I get this instead of the output window shown: "Using display 0 Cannot create lock file as an old version of QVFb has opened /tmp/qtembedded-root/QtEmbedded-0. Close other QVFb and try again" I have no idea what this is! I tried fuser -v /dev/fb0 but that didn't show anything, and "fuser -k -KILL /dev/fb0" didn't work either! Even running as root didn't work! I've attached the build output as a txt attachment. Please do help me out! What do I do?
Unable to Access Framebuffer
The complete error given is ""Using display 0 Cannot create lock file as an old version of QVFb has opened /tmp/qtembedded-root/QtEmbedded-0. Close other QVFb and try again Can't open framebuffer device /dev/fb0 driver cannot connect" is it a driver issue?
