I got my mini2440 board to work using WPA2-PSK with an USB dongle as
described in previous WLAN post.
I have DHCP script that works with the Ethernet connection.
1) How can I make my WPA2-PSK connection use DHCP instead of a static IP?
2) Is it possible to use WPA2-AES instead of WPA2-PSK?
Does wpa_supplicant support it?
config:
network={
ssid="DENGEBT"
key_mgmt=WPA-PSK
proto=WPA
pairwise=CCMP TKIP
group=CCMP TKIP
psk="1234"
Startup:
ifconfig eth0 down
iwconfig wlan0 essid "DENGEBT" channel 4
ifconfig wlan0 192.168.1.111 up
route add default gw 192.168.1.2
echo "nameserver 10.0.0.2"> /etc/resolv.conf
wpa_supplicant -D wext -i wlan0 -c /etc/wpa-psk-tkip.conf &
Any Help would be appreciated.
WPA2-AES , WPA2-PSK DHCP
Hello David! I would like to use wpa_supplicant too. can you be so kind to say me how you add this package to kernel? regards
I did this: $ wpa_supplicant -B -Dwext -iwlan0 -c/etc/wpa_supplicant.conf It enables the access and the encryption to the wireless net And then I run a simple $ dhclient wlan0 That's all (at least here on my system).
