Cual es el maximo voltaje que se puede aplicar a las entradas analogicas (AIN) del MINI2440. Los esquematicos muestran solo la conexion a 3.3v... 5 voltios es posible?
AIN max voltaje Input
What is the maximum voltage that can be applied to the analog inputs (AIN) of MINI2440. The schematic shows only the connection to 3.3v ... 5 volts is possible?
Grab the datasheet off the downloads page. Whereas, some GPIO is 5V tolerant I suspect you are limited to 3V3 on the ADC inputs. Good luck
I've read the datasheet and makes no reference to the maximum voltage that can withstand MINI2440 ADC. Just to mention that it connected to a 3.3V reference voltage. I need to accurately measure a variation of 0-5V. I would try connecting 5V but I have fear of burning or MINI2440 port.
Looks like you are right. The only thing that seems relevant is a analog core voltage rating of 3.3V I know on the AVR atmega series that you have access to the supply pin for the ADC, which allows you to change it. Doesn't look like you have that freedom on the S3C2440. When I looked last time at which I/O was 5Volt tolerant am I sure I found some that where, although a search on <6.5> and <tolerant> didn't show anything up this time. I get the impression that the ADC is really meant only for running the touchscreen and if you want to do some serious measurements then an out-board ADC is warranted. Good luck
