I compiled a kernel from buserror's git repository but it hangs after detecting usb without any error... mmc0: new SD card at address 0002 mmcblk0: mmc0:0002 00000 1.88 GiB mmcblk0: s3c2410-rtc s3c2410-rtc: setting system clock to 2150-06-11 20:48:51 UTC (1399299635) p1 p2 Waiting for root device /dev/mtcblk0p2... usb 1-1: new full speed USB device using s3c2410-ohci and address 2 usb 1-1: configuration #1 chosen from 1 choice hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected Any ideas?
Kernel Hangs after detecting USB
Using the kernel from FriendlyARM, I got this message: VFS: Cannot open root device "mtcblk0p2" or unknown-block(2,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 5120 mtdblock2 (driver?) 1f03 125568 mtdblock3 (driver?) 1f04 131072 mtdblock4 (driver?) b300 1974272 mmcblk0 driver: mmcblk b301 49010 mmcblk0p1 b302 1925080 mmcblk0p2 Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) Backtrace: [<c0035270>] (dump_backtrace+0x0/0x10c) from [<c03958f0>] (dump_stack+0x18/0x1c) r7:c04c6440 r6:c0503ed0 r5:c39dc000 r4:c3823f40 [<c03958d8>] (dump_stack+0x0/0x1c) from [<c0395940>] (panic+0x4c/0x134) [<c03958f4>] (panic+0x0/0x134) from [<c0008e9c>] (mount_block_root+0x178/0x234) r3:00000000 r2:c383f9ec r1:c3823f40 r0:c0453720 [<c0008d24>] (mount_block_root+0x0/0x234) from [<c0009008>] (mount_root+0xb0/0xf4) [<c0008f58>] (mount_root+0x0/0xf4) from [<c0009144>] (prepare_namespace+0xf8/0x190) r7:c05038a0 r6:c0021808 r5:c0021808 r4:c0021818 [<c000904c>] (prepare_namespace+0x0/0x190) from [<c00084c0>] (kernel_init+0xf0/0x124) r7:00000000 r6:c00200dc r5:c00205d4 r4:c00205d4 [<c00083d0>] (kernel_init+0x0/0x124) from [<c004d1a4>] (do_exit+0x0/0x62c) r7:00000000 r6:00000000 r5:00000000 r4:00000000 which is very strange since my boot args are: bootargs=console=ttySAC0,115200 root=mtcblk0p2 rw ip=off init=/bin/sh mini2440=1tb rootfstype=ext3 rootdelay=10
> bootargs=[..] root=mtcblk0p2 There's no device of this name in the list of available partitions. Use mmcblk0p2 which is probably what you meant.
I already corrected that but I still get the same message. Waiting 10sec before mounting root device... s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SD card at address 0002 mmcblk0: mmc0:0002 00000 1.88 GiB (ro) mmcblk0: p1 p2 Root-NFS: No NFS server available, giving up. VFS: Unable to mount root fs via NFS, trying floppy. VFS: Cannot open root device "mmcblk0p2" or unknown-block(2,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 5120 mtdblock2 (driver?) 1f03 125568 mtdblock3 (driver?) b300 1974272 mmcblk0 driver: mmcblk b301 49010 mmcblk0p1 b302 1925080 mmcblk0p2 Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
