Can anyone tell how to compile CEplayer available with wince .
CE player compilation
Hi, well, you can add this to your winCE image, as another component. Just add Windows Media Player, maybe SYSGEN_CEPLAYER, but i'm not sure (i don't have Platform Builder right now). But, if you want to compile alone, because you need to do some modifications, look in (case WinCE 6) c:\wince600\public ... search for a directory called CEPlayer, there are source files. I recommend you to copy that directory and use sourcefiles in order to create a new project in VS2005, using option Smart Device, and compile this project alone. There will be some problems, first, because VS2005 doesn't found some .h files, look for them in c:\wince600 and add directory's file in your project properties. Then, you will start to have problems with linker: look in internet about function with problem plus msdn (for example, function_with_problem + msdn), so you will have documentation about function. Then, check about libraries required, for example library_you_need.lib, and look for it again in you hard disk; it should be in your SDK directory (c:\wince600\platform\mini2440\... ), don't use libraries for other platforms than you are using. The, repeat the procedure done with .h file: add directory where library "lives" in project properties (in linker options). You should repeat this steps for many files, but usually are 3 or 4 files. Then, your compile and link will finish. Maybe other ways cleaner to do this, but this works for me. Why do you need compile ceplayer? are you modifing it? do you need video files in mini2440 or just audio files? See you! Leo
