Hi, I am new developing WinCE/Compact Framework applications and I would like to know if it is posible to connect a Client/Server program taking advance of USB ActiveSync connection. Right now, I have developed a client(PC) / server(Mini2440) system where the application running in Mini2440 listens for incoming TCP conections. The applications works fine when i tested them over an actuall Ethernet network. I found that when an ActiveSync connection is made, this connection is take by Windows CE as an IP one (Under properties of "USB CABLE" you will see 192.168.55.101 as the address). Unfortunately I can't ping this address from the PC neither establish a TCP connection. By googling I found that the capabilities to use ActiveSync as an actuall network connection depends whether Remote NDIS is enabled in the device. I search for this feature in the BSP catalog, but NDIS is unchecked, so I checked it and tryed to make a Clean Sysgen, but the compilation is not successful. http://img4.glowfoto.com/images/2010/06/29-1600403843L.jpg Can someone help me with this or point me in the right direction?. Thanks in advance and best regards.
TCP/IP over ActiveSync
Hello Dom. Thanks for your answer. Finally I could build the image by disabling the Antivirus. The feature that I enabled is shown in the attachment file, but it didn't make any difference. I can't ping the device's ActiveSync IP address, neither a virtual network adapter is shown under "Netwok Connections" in the PC. Thanks in advance for your help.
Fernando, did you got any advance in your tests ??? I'm trying to do the samething ... thanks, Cristiano ps:by the way, are you brazilian ?
Hi Cristiano. Sadly I had to leave my tests, becouse they took many time and I didn't get any advance. As reference here is the link to a thread I opened in MSDN Forums in that regard. I tried all the tweaks I was told, but didnīt get any concrete result. http://social.msdn.microsoft.com/Forums/sr-Latn-CS/windowsmobiledev/thre...
Hi Fernando, I,m not an expert in developing Wince aplications,in fact I never have worked with it. I,m developing my aplication in Labview,it is a graphical language. I have the mini2440 with an .nb0 image for 4,3" from developmentboard.net loaded in ram. I connect the ethernet cable but only the link led is on, the activity one is always off, and I canīt find how to configure the ethernet in the mini2440, could you please help me?,maybe I need to develop an aplication for Wince?. Thanks in advance Icaro
