Hi, I am trying to install a wince 6.0 image in a mini2440 board with a 7" display. I tried several images (domodom, etc..) but I have had always the same result: the board reboots all the time and I can see the message "load WinCE Image.." repeatedly. (hyperterminal) The 7" display shows a short yellow progress bar (only a 1/4 of the screen) that seems that the image is not correct for this display but I sent the NK_A70.bin. Any Idea? Can you help me, please? Thanks in advance.
Wince 6.0 reboot
Hello Oscar, I never had such a problem, but I don't think your problem comes from the display setting of your image (you would have a working image without a good display). It seems that many problems come from the power supply. If you can find another one, try it. You could also try to start up your board without the display and see if the board reboots all the time. Best regards domodom
Hi domodom, First, thanks for you answer. You had reason, the problem was the power supply. I changed it and runs OK. Thanks one more time. Oscar
