Hi, I am trying to bring up the mini 2440 , But i am getting the "Kernel panic - not syncing: Attempted to kill init!", If some one can throw light in this regard will be helpful and highly appreciable. Here is the boot log :- U-Boot 1.3.2-mini2440 (Oct 6 2009 - 12:51:09) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: 128 MiB Found Environment offset in OOB.. USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:00:2f:00:00:06 Hit any key to stop autoboot: 0 trying to detect SD Card... Manufacturer: 0x1b, OEM "SM" Product name: "SD ", revision 1.0 Serial number: 3927984417 Manufacturing date: 2/2010 CRC: 0x4e, b0 = 1 READ_BL_LEN=15, C_SIZE_MULT=7, C_SIZE=3453 size = 2329935872 2060420 bytes read ## Booting kernel from Legacy Image at 31000000 ... Image Name: Created: 2010-03-26 5:54:15 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2060356 Bytes = 2 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux........................................................................... .......................................................... done, booting the kernel. Linux version 2.6.27 (root@tom) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #1 PREEMPT Mon Aug 24 17:01:35 CST 2009 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 Machine: FriendlyARM Mini2440 development board Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) MM: CPU does not support supersection mapping for 0x55000000000 at 0xf0d00000 S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz S3C24XX Clocks, (c) 2004 Simtec Electronics CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=1tb rootdelay=3 init=/linuxrc irq: clearing pending status 02000000 irq: clearing subpending status 00000002 PID hash table entries: 256 (order: 8, 1024 bytes) timer tcon=00500000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57 Console: colour dummy device 80x30 console [ttySAC0] enabled Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60188KB available (3896K code, 636K data, 116K init) SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok net_namespace: 288 bytes NET: Registered protocol family 16 S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4800000, irq 33 DMA channel 1 at c4800040, irq 34 DMA channel 2 at c4800080, irq 35 DMA channel 3 at c48000c0, irq 36 S3C244X: Clock Support, DVS off SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 NetWinder Floating Point Emulator V0.97 (double precision) ashmem: initialized NTFS driver 2.1.29 [Flags: R/W DEBUG]. yaffs Aug 24 2009 16:57:57 Installing. msgmni has been set to 117 io scheduler noop registered (default) Console: switching to colour frame buffer device 30x20 fb0: s3c2410fb frame buffer device adc initialized input: buttons as /class/input/input0 buttons initialized leds initialized s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 brd: module loaded loop: module loaded nbd: registered device at major 43 logger: created 64K log 'log_main' logger: created 256K log 'log_events' logger: created 64K log 'log_radio' dm9000 Ethernet Driver, V1.31 Now use the default MAC address: 08:90:90:90:90:90 eth0: dm9000e at c4804000,c4806004 IRQ 51 MAC: c3908934 (friendly-arm) usbcore: registered new interface driver zd1211rw usbcore: registered new interface driver zd1201 Linux video capture interface: v2.00 ovcamchip: v2.27 for Linux 2.6 : OV camera chip I2C driver usbcore: registered new interface driver ov511 ov511: v1.64 for Linux 2.5 : ov511 USB Camera Driver Driver 'sd' needs updating - please use bus_type methods S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit) NAND_ECC_NONE selected by board driver. This is not recommended !! Scanning device for bad blocks Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit": 0x00000000-0x00060000 : "supervivi" 0x00060000-0x00260000 : "Kernel" 0x00260000-0x40260000 : "root" mtd: partition "root" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x7da0000 0x00000000-0x40000000 : "nand" mtd: partition "nand" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x8000000 s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes mice: PS/2 mouse device common for all mice usbcore: registered new interface driver appletouch input: s3c2410 TouchScreen as /class/input/input1 s3c2410 TouchScreen successfully loaded S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver s3c2440-i2c s3c2440-i2c: slave address 0x10 s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter mapped channel 0 to 0 s3c2440-sdi s3c2440-sdi: powered down. s3c2440-sdi s3c2440-sdi: initialisation done. s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). usbcore: registered new interface driver hiddev s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver UDA1341 audio driver initialized failed to get memory region resouce s3c2410-iis: probe of s3c2410-iis.0 failed with error -2 TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SD card at address b368 mmcblk0: mmc0:b368 SD 1981440KiB mmcblk0: p1 p2 p3 s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time Waiting 3sec before mounting root device... kjournald starting. Commit interval 5 seconds EXT3 FS on mmcblk0p3, internal journal EXT3-fs: recovery complete. EXT3-fs: mounted filesystem with ordered data mode. VFS: Mounted root (ext3 filesystem). Freeing init memory: 116K Warning: unable to open an initial console. Kernel panic - not syncing: Attempted to kill init! ======================= I wonder if this failure is the cause of kernel panic :- failed to get memory region resouce s3c2410-iis: probe of s3c2410-iis.0 failed with error -2 Thank you Ranganath.S
Chances are you're using friendlyarm kernel with a custom FS To solve the problem: Set in the kernel .config file CONFIG_ARM_THUMB=y CONFIG_AEABI=y Or in the make menuconfig System Type->Support Thumb user binaries Kernel Features->Use the ARM EABI to compile the kernel Rebuild the kernel and it should be ok Cheers Paul
i have the same problem [code] Kernel panic - not syncing: Attempted to kill init![/code] and rebuild kernel with System Type->Support Thumb user binaries Kernel Features->Use the ARM EABI to compile the kernel and still have the same error !!!!!
I have asked: which root filesystem you are using? Maybe it is a different command than /linuxrc you need to set in the boot parameters. init=/bin/bash should always work on every linux root filesystem.
ERROR in detail
VFS: Mounted root (ext3 filesystem) on device 179:3.
Freeing init memory: 124K
usb 1-1: New USB device found, idVendor=0a81, idProduct=0101
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1: Product: USB Keyboard
usb 1-1: Manufacturer: CHESEN
usb 1-1: configuration #1 chosen from 1 choice
input: CHESEN USB Keyboard as
/devices/platform/s3c2410-ohci/usb1/1-1/1-1:1.0/i1
generic-usb 0003:0A81:0101.0001: input: USB HID v1.10 Keyboard [CHESEN USB
Keyb0
init: I won't write compressed data to a terminal.
/devices/platform/s3c2410-ohci/usb1/1-1/1-1:1.1/i2
generic-usb 0003:0A81:0101.0002: input: USB HID v1.10 Device [CHESEN USB
Keyboa1
init: For help, type: `init --help'.
i m also same error like the following for samsung2450 board. is anybody got solution for this? Uncompressing Linux... done, booting the kernel. Linux version 2.6.33.6 (root@ubntu-desktop) (gcc version 4.2.2) #12 Mon Jul 26 18:39:19 IST 2010 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: SMDK2450 Ignoring unrecognised tag 0x00000000 Memory policy: ECC disabled, Data cache writeback CPU S3C2450 EVT3 (id 0x32450003) SPA epll 80200102 Mpll 80640061 clkdiv0 557 S3C24XX Clocks, (c) 2004 Simtec Electronics S3C2450: mpll on 800.000 MHz, cpu 400.000 MHz, mem 133.333 MHz, pclk 66.666 MHz S3C2450: epll on 96.000 MHz, usb-bus 48.000 MHz Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: root=/dev/ram0 initrd=0x30800000,16M ramdisk=32768 init=/bin/sh console=ttySAC3,115200 mem=64M PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 45432KB available (2588K code, 271K data, 116K init, 0K highmem) Hierarchical RCU implementation. NR_IRQS:109 irq: clearing subpending status 02000006 irq: clearing subpending status 02000002 timer tcon=00000000, tcnt 28af, tcfg 00000f00,00000000, usec 00007ae2 Console: colour dummy device 80x30 console [ttySAC3] enabled Calibrating delay loop... 398.95 BogoMIPS (lpj=997376) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 whats up blady hello entered machine init S3C Power Management, Copyright 2004 Simtec Electronics S3C2450: Initialising architecture SPA s3c2450_init S3C2450: IRQ Support bio: create slab <bio-0> at 0 SCSI subsystem initialized NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (no cpio magic); looks like an initrd Freeing initrd memory: 16384K NetWinder Floating Point Emulator V0.97 (double precision) JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. ROMFS MTD (C) 2007 Red Hat, Inc. msgmni has been set to 120 alg: No test for stdrng (krng) Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) brd: module loaded loop: module loaded Uniform Multi-Platform E-IDE driver ide-gd driver 1.18 ide-cd driver 5.00 PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256). CSLIP: code copyright 1989 Regents of the University of California. mice: PS/2 mouse device common for all mice TCP cubic registered RAMDISK: gzip image found at block 0 EXT2-fs (ram0): warning: maximal mount count reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem) on device 1:0. Freeing init memory: 116K Warning: unable to open an initial console. Kernel panic - not syncing: Attempted to kill init!
Hi Have you solved the issue? We are also facing the same issue with SMDK2450 board. We use cramfs and our bootargs are: root=/dev/ram0 initrd=0x30800000,16M ramdisk=20000 init=/bin/bash console=ttySAC0,115200 mem=64M. Thanks and regards Rajam QMax systems
To track this best would be add to kernel parameter also: user_debug=31 to see why panic occurred. Juts post some lines from end then. Marek
Hi, Thanks - as said we added user_debug=31 to the bootargs and we got message, [1] linuxrc: obsolete system call 00000000. Code: e08f1001 e1a0c000 e3a0702d ef000000 (e3700a01) in the log. Then we took help from net and recompiled the kernel after enabling "Use the ARM EABI to compile the kernel" in "Kernel Features". The issue is resolved now and system is up. Thanks and regards Rajam QMax Systems
I had builded a filesystem using CLFS http://cross-lfs.org/view/clfs-embedded/arm/index.html .... I had converted that CLFS using mkfs tools using command : # mkfs.jffs2 -r clfs -o clfs.jffs2 -e 16 -l -n And ported a clfs.jffs2 on my mini2440 friendly arm .... But Now I m getting a following error.... Advanced Linux Sound Architecture Driver Version 1.0.20. No device for DAI UDA134X No device for DAI s3c24xx-i2s S3C24XX_UDA134X SoC Audio driver UDA134X SoC Audio Codec asoc: UDA134X <-> s3c24xx-i2s mapping ok ALSA device list: #0: S3C24XX_UDA134X (UDA134X) TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. lib80211: common routines for IEEE802.11 drivers s3c2410-rtc s3c2410-rtc: setting system clock to 2011-02-04 14:25:36 UTC (1296829536) VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 120K Kernel panic - not syncing: Attempted to kill init! [<c002b4c8>] (unwind_backtrace+0x0/0xdc) from [<c0303010>] (panic+0x34/0x118) [<c0303010>] (panic+0x34/0x118) from [<c003be20>] (do_exit+0x60/0x570) [<c003be20>] (do_exit+0x60/0x570) from [<c003c3b4>] (do_group_exit+0x84/0xb8) [<c003c3b4>] (do_group_exit+0x84/0xb8) from [<c0045838>] (get_signal_to_deliver+0x2f4/0x330) [<c0045838>] (get_signal_to_deliver+0x2f4/0x330) from [<c0028f34>] (do_signal+0x64/0x4a8) [<c0028f34>] (do_signal+0x64/0x4a8) from [<c0026e6c>] (work_pending+0x1c/0x20)
I am also facing the same issue on my OMAP3530 LV SOM zoom kit. Can any one
help me in solving this.
Texas Instruments X-Loader 1.4.2 (Feb 7 2011 - 12:46:12)
Xloader misc_init_r done
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.08-rc2/ (Feb 07 2011 - 10:48:41)
OMAP3530-GP ES3.1, CPU-OPP2 L3-165MHz
OMAP3 Logic + LPDDR/NAND
DRAM: 128 MB
NAND: 256 MiB
NAND: HW ECC selected
*** Warning - bad CRC or NAND, using default environment
Board: LV SOM
NOR: initialize in sync mode
Die ID #6db000040000000004035c141001500c
Read production data: done
Part Number : 1012637
Model Name : SOMOMAP3530-10-1672IFCR-C
Serial Number: 3209M00474
Wired Lan MAC: 00:08:ee:03:5d:a6
Wirless MAC: 00:08:ee:03:5d:a7
Net: smc911x-0
======================NOTICE============================
This is the first time that you boot up this board. You are
required to set a valid display for your LCD panel.
Enter the display number of the LCD panel(none for no LCD panel)
Pick one of:
2 == LQ121S1DG31 TFT SVGA (12.1) Sharp
3 == LQ036Q1DA01 TFT QVGA (3.6) Sharp w/ASIC
5 == LQ064D343 TFT VGA (6.4) Sharp
7 == LQ10D368 TFT VGA (10.4) Sharp
15 == LQ043T1DG01 TFT WQVGA (4.3) Sharp
MAKE SURE YOUR DISPLAY IS CORRECTLY ENTERED!
Please enter your LCD display number:15
display=15
Saving Environment to NAND...
Erasing Nand...
Erasing at 0xffe0000 -- 100% complete.
Writing to Nand... done
mmc1 is available
reading uImage
2256832 bytes read
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-2.6.29-rc3-omap1
Data Size: 2256768 Bytes = 2.2 MB
Load Address: 80008000
Entry Point: 80008000
OK
Starting kernel ...
Uncompressing
Linux version 2.6.29-rc3-omap1 (root@surya-desktop) (gcc version 4.4.0
(GCC) ) 1
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Logic 35x LV SOM Board
OMAP3530 ES3.1 (full speed SGX, IVA2)
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
Reserving 15728640 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: display=15 console=ttyS0,115200 root=/dev/mmcblk0p2 rw
init
omap3logic_display_selection:133
Standard display=480:272:2:2:6:2:41:10:10000:1048635
SDRC tDAL: 5 ticks 37 ns
SDRC tDPL: 2 ticks 15 ns
SDRC tRRD: 2 ticks 15 ns
SDRC tRCD: 3 ticks 22 ns
SDRC tRP: 3 ticks 22 ns
SDRC tRAS: 6 ticks 45 ns
SDRC tRC: 8 ticks 60 ns
SDRC tRFC: 15 ticks 112 ns
SDRC tXSR: 19 ticks 142 ns
Clocking rate (Crystal/DPLL/ARM core): 26.0/266/500 MHz
Reprogramming SDRC
dpll3_m2_clk rate change failed: -22
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 512 (order: 9, 2048 bytes)
OMAP clockevent source: GPTIMER12 at 32768 Hz
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 109424KB available (4056K code, 755K data, 160K init, 0K highmem)
Calibrating delay loop... 477.86 BogoMIPS (lpj=1863680)
net_namespace: 520 bytes
MUX: setup AD1_34XX_GPIO_153 (0xd8002186): 0x0101 -> 0x011c
MUX: setup J21_34XX_I2C1_SDA (0xd80021bc): 0x0118 -> 0x0118
MUX: setup K21_34XX_I2C1_SCL (0xd80021ba): 0x0118 -> 0x0118
MUX: setup AG14_34XX_I2C3_SDA (0xd80021c4): 0x0118 -> 0x0118
MUX: setup AF14_34XX_I2C3_SCL (0xd80021c2): 0x0118 -> 0x0118
MUX: setup AE1_34XX_GPIO152 (0xd8002184): 0x0101 -> 0x011c
MUX: setup P27_34XX_GPIO126 (0xd8002150): 0x0118 -> 0x011c
MUX: setup V3_34XX_HSUSBHS2_DATA3_GPIO182 (0xd80021de): 0x0113 -> 0x011c
MUX: setup T28_3430_USB0HS_PHY_CLK (0xd80021a2): 0x0100 -> 0x0108
MUX: setup T25_3430_USB0HS_PHY_STP (0xd80021a4): 0x0018 -> 0x0108
MUX: setup R28_3430_USB0HS_PHY_DIR (0xd80021a6): 0x0100 -> 0x0108
MUX: setup T26_3430_USB0HS_PHY_NXT (0xd80021a8): 0x0100 -> 0x0108
MUX: setup T27_3430_USB0HS_PHY_D0 (0xd80021aa): 0x0100 -> 0x0108
MUX: setup U28_3430_USB0HS_PHY_D1 (0xd80021ac): 0x0100 -> 0x0108
MUX: setup U27_3430_USB0HS_PHY_D2 (0xd80021ae): 0x0100 -> 0x0108
MUX: setup U26_3430_USB0HS_PHY_D3 (0xd80021b0): 0x0100 -> 0x0108
MUX: setup U25_3430_USB10S_PHY_D4 (0xd80021b2): 0x0100 -> 0x0108
MUX: setup V28_3430_USB0HS_PHY_D5 (0xd80021b4): 0x0104 -> 0x0108
MUX: setup V27_3430_USB0HS_PHY_D6 (0xd800...stripped-down
MUX: setup V27_3430_USB0HS_PHY_D6 (0xd80021b6): 0x0100 -> 0x0108
MUX: setup V26_3430_USB0HS_PHY_D7 (0xd80021b8): 0x0100 -> 0x0108
Found NAND on CS0
Registering NAND on CS0
MUX: setup D28_DSS_PCLK (0xd80020d4): 0x0000 -> 0x0000
MUX: setup D26_DSS_HSYNC (0xd80020d6): 0x0000 -> 0x0000
MUX: setup D27_DSS_VSYNC (0xd80020d8): 0x0000 -> 0x0000
MUX: setup E27_DSS_ACBIAS (0xd80020da): 0x0000 -> 0x0000
MUX: setup AG22_DSS_D0 (0xd80020dc): 0x0000 -> 0x0000
MUX: setup AGH22_DSS_D1 (0xd80020de): 0x0000 -> 0x0000
MUX: setup AG23_DSS_D2 (0xd80020e0): 0x0000 -> 0x0000
MUX: setup AH23_DSS_D3 (0xd80020e2): 0x0000 -> 0x0000
MUX: setup AG24_DSS_D4 (0xd80020e4): 0x0000 -> 0x0000
MUX: setup AH24_DSS_D5 (0xd80020e6): 0x0000 -> 0x0000
MUX: setup E26_DSS_D6 (0xd80020e8): 0x0000 -> 0x0000
MUX: setup F28_DSS_D7 (0xd80020ea): 0x0000 -> 0x0000
MUX: setup F27_DSS_D8 (0xd80020ec): 0x0000 -> 0x0000
MUX: setup G26_DSS_D9 (0xd80020ee): 0x0000 -> 0x0000
MUX: setup AD28_DSS_D10 (0xd80020f0): 0x0000 -> 0x0000
MUX: setup AD27_DSS_D11 (0xd80020f2): 0x0000 -> 0x0000
MUX: setup AB28_DSS_D12 (0xd80020f4): 0x0000 -> 0x0000
MUX: setup AB27_DSS_D13 (0xd80020f6): 0x0000 -> 0x0000
MUX: setup AA28_DSS_D14 (0xd80020f8): 0x0000 -> 0x0000
MUX: setup AA27_DSS_D15 (0xd80020fa): 0x0000 -> 0x0000
MUX: setup G25_DSS_D16 (0xd80020fc): 0x0000 -> 0x0000
MUX: setup H27_DSS_D17 (0xd80020fe): 0x0000 -> 0x0000
MUX: setup H26_DSS_D18 (0xd8002100): 0x0000 -> 0x0000
MUX: setup H25_DSS_D19 (0xd8002102): 0x0000 -> 0x0000
MUX: setup E28_DSS_D20 (0xd8002104): 0x0000 -> 0x0000
MUX: setup J26_DSS_D21 (0xd8002106): 0x0000 -> 0x0000
MUX: setup AC27_DSS_D22 (0xd8002108): 0x0000 -> 0x0000
MUX: setup AC28_DSS_D23 (0xd800210a): 0x0000 -> 0x0000
MUX: setup AC1_34XX_GPIO_155 (0xd800218a): 0x0101 -> 0x010c
MUX: setup AF21_SYS_BOOT6_GPIO_8 (0xd8002a16): 0x0004 -> 0x0004
OMAP DMA hardware revision 4.0
USB: No board-specific platform config found
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
OMAP DSI rev 1.0
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
MUX: setup AH8_34XX_GPIO29 (0xd80025fa): 0x0113 -> 0x0104
omap2_init_single_mmc: starting..
omap2_init_single_mmc: MMC0
i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
ashmem: initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
msgmni has been set to 214
io scheduler anticipatory registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
console [ttyS0] enabled
brd: module loaded
loop: module loaded
smsc911x: Driver version 2008-10-21.
smsc911x-mdio: probed
eth0: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=ffffffff:01,
irq=-1)
net eth0: MAC Address: 00:08:ee:03:5d:a6
usbcore: registered new interface driver catc
catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
usbcore: registered new interface driver kaweth
pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
gspca: main v2.4.0 registered
input: triton2-pwrbutton as /devices/virtual/input/input0
triton2 power button driver initialized
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V
16-b)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on "omap2-nand":
0x000000000000-0x000000080000 : "X-Loader"
0x000000080000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000680000 : "Kernel"
0x000000680000-0x000010000000 : "File System"
isp1761_register_driver(drv=c04587c4)
isp1760 isp1760.0: ST-ERICSSOON ISP1761
isp1760 isp1760.0: new USB bus registered, assigned bus number 1
isp1760 isp1760.0: irq 286, io mem 0x00000000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: ST-ERICSSOON ISP1761
usb usb1: Manufacturer: Linux 2.6.29-rc3-...stripped-down
Hi Sorry, my complete system log is getting stripped down.......
kindly see the below & help me as soon as possible
usb usb1: Manufacturer: Linux 2.6.29-rc3-omap1 ISP1761HCD
usb usb1: SerialNumber: ISP1761
hub 1-0:1.0: 1 port detected
drivers/usb/pehcd/hal/hal_x86.c: Registered Driver ISP1761HCD
Host Driver has been Registered<6>android init
android_bind
mass_storage_function_add
android_usb gadget: Number of LUNs=1
adb_function_add
android_usb gadget: android_usb ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.29-rc3-omap1 musb-hcd
usb usb2: SerialNumber: musb_hdrc
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
twl4030_vaux1_ldo_use:17
twl4030_vaux1_ldo_use: turn VAUX1 on!
tsc2004_detect_irq: gpio_pin 153 gpio_irq 313
tsc2004_driver_register: irq 313
input: tsc2004 as /devices/virtual/input/input1
tsc2004 - registering input device
tsc2004: device address 0x48 attached.
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
twl4030_rtc twl4030_rtc: Power up reset detected.
twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC.
usb 1-1: new high speed USB device using isp1760 and address 2
Advanced Linux Sound Architecture Driver Version 1.0.19.
ALSA device list:
#0: Dummy 1
NET: Registered protocol family 15
Power Management for TI OMAP3.
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
mmc0: new SD card at address 31c3
mmcblk0: mmc0:31c3 SR01G 945 MiB
mmcblk0: p1 p2 p3
Display already enabled
Buffer Size = 3686400
omap_vout: registered and initialized video device 0
[v4l2]
omap_vout: registered and initialized video device 1
[v4l2]
display->updated
twl4030_rtc twl4030_rtc: hctosys: invalid date/time
EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
EXT3 FS on mmcblk0p2, internal journal
VFS: Mounted root (ext3 filesystem) on device 179:2.
Freeing init memory: 160K
I found that the manual that comes along with friendly arm board does not have the right hardware information. Identify the NAND flash size and load the binaries accordingly. K9F1208 - 64MB flash K9F1G08 - 128MB flash K9F2G08 - 256MB flash K9F8G08 - 1024MB flash if your flash size is 128MB then load supervivi-128M.img and root-qtopia-128M.img,Dont load the following images supervivi-64M.img and root-qtopia-64M.img.The specified images is for 64M flash. Steps to load: 1.Install the supervivi bootloader 2.Install the kernel. 3.Install the yaffs. choose the appropriate image for right flash size.
To everyone having the "unable to open an initial console. " error: please check if your rootfs has the /dev/console node. I'm not sure, but I think I've had a similar problem.
