If I enter the IP of my mini2440 the message "The Windows Embedded CE Web Server is enabled on this device. This file is a placeholder and should be replaced. Please see your Platform Builder docs or our web site at http://msdn.microsoft.com/embedded." appears. Then I tried to change the HTML file in the path .../windows/www to another HTML contains a simple text too. But when I know enter the IP the Text "Access denied The requested action is not allowed" appears! What do I wrong?
How to use the Webserver ?
Hey I see your topic and I also try access the default webserver page on
the mini and it works fine.
I also change the default web page to another with text and images and it
works fine too.
So I guess there should be something you miss, in case you should try to
repeat what I do to see if it works on your board Im goin to write what I
do.
first the conecction I try is on a computer to computer conecttion with a
crossed Ethernet cable. So I connect the mini to my laptop and then I check
the IP that the mini automatically loaded and the subnet mask.
Then I manually configure the TCP/IP on my lap (Win XP) to match exactly
the subnet mask and then put an IP that seems closely enough to the mini
Example: Mini IP: 168.125.85.110
Mini Subnet: 255.255.0.0
(the mini automatically gets this when I plug in the ethernet cable in teh
to computers)
Lap IP: 168.125.85.100
Subnet: 255.255.0.0
Once done this in my lap browser I type the IP of the mini2440 and if
everything is fine you should see the default web page as I do.
then I replace the default.htm file in the mini for a index.htm file I get
and restart the mini2440 (dunno exactly if thats necesary at the moment I
will find out later =P ) but once its done and reload the browser page on
my browser the page displayed was the one I just replace.
So let me know if you did the same or if there is something you miss to see
what could be wrong.
Hope this info is useful and hope you get it all working.
Have a nice day.
Dear sir, I have tried out as you said. But it wont work . What shoud i do ? Please help? I am getting stuck. Thnaking you.
