Hi everbody; I have mini2440 3.5" and 128 Kb nand. I have a any problem. I'm try create wince 6.0 image and upload my device. But I dont work any navigation software. for example igo, destinator etc etc. I get memory error. I want change Start > Settings > Control Panel > System > Memory Tab but I can't change memory slider. slider is going to right. I'm searching internet. Some web sites is say you must change autosize value or SetSystemMemoryDivision() value but I don't find in 2440bsp. some web sites is says ; autosize = off compression=on profile=off romwidth=128 romflags=00 kernelfixups=on I'm create image. No problem. But upload is not complated. I have memory error. I try writting software my car. And I want to use this device as a carpc. But memory not enough memory. I want use max memory for software( for example navigator software or my software) And if possible I want use extended memory (sd card or usb flash) How I do. Or how do chanege BSB adjustment Thanks for helps.
Navigator sofwware & memory problem
The WHOLE nk.bin gets loaded into RAM. This uses up half of ram. If you want more ram then remove things like .netcf from the image and rather install it later.
http://www.friendlyarm.net/forum/topic/455 this was a big help for me.
