Hi to every body i have a doubt: i have install a webserver on my mini2440 and i need to it cans run php. So i configure it. but after that appearsme this mistake: could not find interpreter in 'usr/.../../' so do i have to make a cross compile of this interpreter?? if it does right can any body giveme some ideas?? thanks!!
cross compile php???
hi i didnt found info about this compile so i decided to make it by myself, but im having some troubles. here is the steps i have been done dowload php and inside this folder i put this instrution: ./configure --host=arm-linux --prefix=/home/cherokee/etc --exec-prefix=/home/cherokee/etc CFLAGS="-march=armv4t -mtune=arm920t -Os -lpthread -lrt" but appears me this mistake: configure: error: xml2-config not found. Please check your libxml2 installation. i downloaded this file and put it on the folder Php5, after this i repeat my instrution, but i happened the same problem.. any ideas?? im going to keep trying thanks
HI again i found this link: http://hi.baidu.com/sunxuxi/blog/item/204a33ecfec436d72f2e210a.html There i found i possible solution, there they have the same problem too Then, there's this error during configure: Configuring extensions checking whether to enable LIBXML support... yes checking libxml2 install dir... no checking for xml2-config path... configure: error: xml2-config not found. Please check your libxml2 installation. this was his solution: So I downloaded libxml2 source code from: http://ftp.debian.org/debian/pool/main/libx/libxml2/libxml2_2.6.16.orig.... Configure and compile just as usual: (Take note that --prefix needs an absolute path.) $ export CC=/usr/arm/bin/arm-linux-gcc $ export CXX=/usr/arm/bin/arm-linux-cpp $ export CPP=/usr/arm/bin/arm-linux-cpp $ ./configure --host=i386-linux-gnu --target=arm --prefix=$PWD/install-a $ make i change some lines: export CROSS_COMPILE=arm-none-linux-gnueabi- export CC=${CROSS_COMPILE}"gcc" export CXX=${CROSS_COMPILE}"g++" ./configure --host=arm-linux --target=arm --prefix=$PWD/install-arm but when i execute make i have this problem: elfgcchack.h:7730: error: 'xmlXPtrNewRangePoints' aliased to undefined symbol 'xmlXPtrNewRangePoints__internal_alias' any ideas?? i think im having some progress in this (little but i keep trying) i hope this can be useful for some else, of course when i finish ejjeje, for now help!!!
excues me but i didnt note this mistake at the end when i executed make:: ,/home/felipe/Escritorio/libxml2-2.6.19/install-arm/lib ./.libs/libxml2.so: undefined reference to `gzopen' ./.libs/libxml2.so: undefined reference to `gzclose' ./.libs/libxml2.so: undefined reference to `deflate' ./.libs/libxml2.so: undefined reference to `gzrewind' ./.libs/libxml2.so: undefined reference to `gzwrite' ./.libs/libxml2.so: undefined reference to `crc32' ./.libs/libxml2.so: undefined reference to `deflateEnd' ./.libs/libxml2.so: undefined reference to `gzdopen' ./.libs/libxml2.so: undefined reference to `deflateInit2_' ./.libs/libxml2.so: undefined reference to `gzread' collect2: ld returned 1 exit status make[2]: *** [xmllint] Error 1 make[2]: se sale del directorio `/home/felipe/Escritorio/libxml2-2.6.19' make[1]: *** [all-recursive] Error 1 make[1]: se sale del directorio `/home/felipe/Escritorio/libxml2-2.6.19' make: *** [all] Error 2 can any body giveme some ideas i think that after this ill could put to run php on mini! thanks
hi made somes changes on my command lines:
./configure --host=arm-linux --target=arm --without-zlib
--prefix=/home/felipe/libxml
it doesnt throwsme mistakes but it doesnt create the folder libxml on
home/felipe
so.. was it a good compile?
its a simple doubt but im comfuse help!!
hi at this moment this its like a monologue, what ever i hope someone could
giveme a hand at this part
im not sure if the problem could be use or not zlib because if i dont use
it, it doesnt create me any files or should i made a wrong compile last
time?? im not sure thats my first doubt
the second i include again zlib on my instrutions
i repeat this instrution:
./configure --host=arm-linux --target=arm --prefix=/opt/install-arm
and after that i checked the some information from the output and i note
this:
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
appending configuration tag "F77" to libtool
Checking zlib
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for gzread in -lz... no
Checking headers
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
if it can read zlib usability why am i still having that problem??
i also made a cross compile of zlib following this steps:
Used version: zlib-1.1.4.tar.gz
After unpacked the sources change to the source directory:
# cd zlib-1.1.4
# CC=arm-linux-gcc \
./configure --prefix=/opt
# make
# make install prefix=/opt
it mades me two folders but include and lib , i move that folder to a new
folder zlib inside opt folder
and tried this code:
./configure --host=arm-linux --target=arm --with-zlib-dir=/opt/zlib
make
but the output was the same problem:
what could be the problem?? HELLLLP!
PHP would be very nice .... if you get managed to crosscompile it... may you please share it? unfornatullly i cannot help you Yours Andreas
Andreas, yeah i going to upload some where but, i need a hand!! this forum tells all the steps i have done. so any one cans followme
i could solve the problem!!! the solution compile zlib with this: http://www.ailis.de/~k/index.php?url=archives/19-ARM-cross-compiling-how... and copy and paste the compiled flies:libz.a,libz.so, libz.so1 libz.o.1.1.4 folder to: /usr/local/arm/4.3.2/arm-none-linux-gnuebi/libc/lib the final configuration i used was this: Code: export CROSS_COMPILE=arm-none-linux-gnueabi- export CC=${CROSS_COMPILE}"gcc" export CXX=${CROSS_COMPILE}"g++" ./configure --host=arm-linux --target=arm --prefix=/opt how ever it didnt create me the compile files why doesnt it create files?? isnt it suppose that it most be create the files where i put on prefix command line? in my case on /opt folder??? Helpp im close
at least i could compile this library i forgot the final step: make install jajajajajaj ;) Now php!!
Do you need the mini2440 just to be a webserver? Why don't you install Debian or Emdebian on it and get rid of all the compile stuff?
Hi david, I think you need to use web server which have "small" memory usage so we can save it for another process. are you familiar with ANSI c? If "yes", you can use g-wan -> http://gwan.com/ (easy to install, 200K), libev -> http://software.schmorp.de/pkg/libev.html or libevent http://monkey.org/~provos/libevent/ they have small foot print, and better performance (trhougput). but if you still use PHP, use cherokee web server -> http://www.cherokee-project.com/benchmarks.html -aris
Im in the same boat David. Trying appweb and php. However, having a hell of a time getting PHP to compile for arm, no matter what settings, it still compiles for x86. What web server are you using it with ? Any chance youd put up the files somewhere ? Specifically the php5lib.so
Hi guys, I got a problem. I am trying to cross compile php for ARM. I could do it but its does'nt generate ".so files". Can anyone help how to get ".so" files. Thanks, Praveen.
Hi guys, your problem are the dependencies of each single solution you want to use. I recommend you look into some BSPs that include both, support for the architecture and has the packages you need. For Mini2440 I'd recommend either the pengutronix BSP (www.ptxdist.org) or OE (www.openembedded.org) you can either create a complete image or only compile the packages you need as .ipk/.opk and install it. It takes less fumbling around and auto-builds the dependencies.
Aris, "you can use g-wan -> http://gwan.com/": Is it open source, can I compile it for ARM? I just found x86 binaries on their website.
