Hi... I'm programming in C# and doing tests on serial port. When I try to open the COM1, my program throws an exception: can not find COM1.So I installed a DeviceManager and I see these connected devices: http://img195.imageshack.us/img195/6009/serialport.png. Can tell me if it's possible to use serial port that is used with DNW? Was I wrong to create the image with Platform Builder? thanks
Serial port COM1 in c#
I inserted the image you find here [url]http://www.andahammer.com/Downloads/mini2440-en.rar[/url] and once installed I see COM1 COM2 COM3.So I think it's a mistake in my Platform Builder.I installed [b]S3C2440a Serial Driver[/b] in Platform Builder, but the problem remains.There is a [u]red X[/u] near [b]S3C2440a Serial Driver[/b] in Platform Builder... Is it a problem? suggestions? thanks
"Catalog item: S3C2440a Serial Driver One or more platform settings are causing this catalog item to be exluded from the image: remove non-platform environment variable: BSP_NOSERIAL. The BSP may be bringing in this variable automatically."
How did you resolve this problem? It told me "SERIAL_SMDK2410.DLL" file was not referenced from the .bib file, so I went to the .bib file and changed line 143 in platform.bib from "serial_smdk2440.dll" to "serial_smdk2410.dll", then copied 2440 files to 2410 and built again. now 2410 files seem to have been automatically cleaned up and build failed with 4 errors.
I had that problem but I solved It: there is a solving: using System.IO.Ports; string[] serialPortList = SerialPort.GetPortNames(); foreach (string item in serialPortList) listBox1.Items.Add(item); And in my device I have COM2 COM3 and COM5
