Hello, I am trying to use the same WinCE5.0 image for 64/128/256MB flash versions of MINI2440. The image works fine on 64/128MB versions but on 256MB it loads good for the first time but later on does not boot from NAND Flash. I am not sure about the nboot. Did anyone had the same problem? This is the VIVI I have: ##### FriendlyARM BIOS 2.0 for 2440 ##### [x] format NAND FLASH for Linux [v] Download vivi [k] Download linux kernel [y] Download root_yaffs image [a] Absolute User Application [n] Download Nboot for WinCE [l] Download WinCE boot-logo [w] Download WinCE NK.bin [d] Download & Run [z] Download zImage into RAM [g] Boot linux from RAM [f] Format the nand flash [b] Boot the system [s] Set the boot parameters [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi [i] Version: 0945-2K Enter your selection: Thanks.
WINCE5.0 256MB Flash Load Error
I have the same problem WinCe5 work in 128mb and 1Gb boards. In the 256mb wince5 run first time and after don't run. I noticed a message through UART1 saying, "Unknown NAND Type" Linux and Wince6 is working in 256mb boards
Mindee, The nboot work for wince6 but is not working to wince5. I don't think nboot is the problem, probably the problem is the WINCE5 BSP that was used to generate the wince5 image.
the new nboot can't boot the old WinCE5/6 before 2010 . and the old nboot can't boot the new wince5/6 after 2010 or later. please check your nboot and wince5 bsp.
I try to use the nboot and images that are in the mini2440 DVD. I think the nboot and images that are inside this DVD are compatible, aren't they? Thanks for response
Mindee, I'm using the images and nboot from one DVD, i'm not mixing. The WinCe5 images from this DVD that worked for 1Gb and 128Mb Boards don't work for 256Mb Board. WINCE6 and Linux working for all. Please with some one have this 256mb board try to install a wince5. I'm going crazy with this. Thanks for responses Mindee.
Try this nboot for 256MB flash.. http://rapidshare.com/files/398198367/nboot_T35.bin.html It should work
I have same problems with wince5 (BSP 2010) and nboot with 256mb board, but I have a A70 touch screen, not a T35 ... Matt_damon, do you have a nboot_A70.bont for my board? thanks a lot
Matt_damon, Thank you, now my T35 is working with wince5, do you have A70 too. And the nboot sources for these T35 and A70. Best Regards.
Can you try this and post the results.. http://rapidshare.com/files/398934235/nboot_A70_256MB.bin.html Also if someone knows the procedure to upload these files onto this website please do
This nboot works very weel as this: http://www.friendlyarm.net/forum/topic/478 ... but my problem persists: winCE is slow with my 256mb board .. I put my image created with PlatformBuilder here if someone wants to use it and gives me help .... http://rapidshare.com/files/399293845/NK_slow_wince5.bin.html thanks
I am not sure about the BSP..so try using the same image which you used for 64MB flash The image for 64/128/256MB Flash MINI2440 is the same.
hi matt_damon with my image and your nboot, how does your board with 256mb work? Slowly? I use this BSP http://www.friendlyarm.net/dl.php?file=wince5-bsp_20100202.zip
I believe I had problem with this BSP... try this BSP http://rapidshare.com/files/399339336/wince-bsp_20090821.zip.html It is the previous verison of BSP also available on this website
before you install 2010's nboot & wince into the nand, please check the supervivi version in NOR flash, it should be 0945-2K or 0945-12
yes,Version: 0945-2K in this guide http://www.friendlyarm.net/dl.php?file=download.pdf is written that I have to insert a supervivi with V comand. Is it necessary? I see no changes
Hi, jeangr For v command , Supervivi or nboot both are available, If you are not sure the boot version, I suggest supervivi. It don't support to show bootlogo.
thanks maybe I found the problem. With a taskManager for winCe I see that the device.exe process uses 99% of cpu with 50/60 threads ... This happens with 2009 and 2010 bsp with my 256mb board ... Why?
maybe, I hope, I found the problem: ActiveSync daemon/process was blocked if I didn't sincronized Wince with my PC ....
@Matt_Damon the link is broken... may you repost it? http://rapidshare.com/files/398934235/nboot_A70_256MB.bin.html
@ Matt_Damon Could you please repost the RS links for the T35 and A70: http://rapidshare.com/files/398198367/nboot_T35.bin.html and http://rapidshare.com/files/398934235/nboot_A70_256MB.bin.html
