hi! while compiling OS in PB -----------------------cut------------------- Total ROM size: 026d8c68 ( 40733800) Error: Ram start overlaps rom binary Rom end : 0x828d8c68 Ram start: 0x82029000 NK physfirst 80200000 physlast 828d8c68 ulRAMFree 82029000 Fatal error hit, exiting... makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec). makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec). -----------------------cut------------------- what correct ram/rom params need config.bib for 128mb flash device? or any other file... thnx!
correct config for 128MB flash
Hi Alex!,
I had encountered the same problem. Check the lines in your config.bib file
that read:
--->Rom end : 0x828d8c68
--->Ram start: 0x82029000<-- This address is less than the ROM end address!
| NK.BIN |
|---------------|<- 0x82029000 = Start of free RAM
|---------------|<- 0x828d8c68 = End of NK.BIN
| Free RAM |
Look for the following entry at the beginning:
RAM 82000000 01FE0000 RAM
Change this to a value greater than 0x828d8c68. You could use the
following:
RAM 83000000 01FE0000 RAM
This will allow the image to be safely before the RAM start address.
Cheers!
Gautam
What would be the correct config for a mini2440 with 1GB? and, if i change the config.bib i can build win ce 6 but i cannot upload it to the device. Any hints on that?
