Hi, I think I'm not the only one who would like to know among all the Angstrom, OPenEmbedded, BuildRoot, etc.... what is the way to develop console and Qt apps. As it's for "regular" devs, i.e. : I would like to do drivers, console and Qt softwares so directly have a uboot+kernel+gcc as explained in the docs doesn't appear to be the best solution.
Among the devs possibilities
on a separate work station. If you are very lucky then with an "emulator" but if you are not so lucky: 1. get your board. 2. get a suitable RELIABLE & STABLE connection between your workstation and your board. 3. get your board working and back it up. 4. start developing your "applications" via a cross compiler , only a madman or sadomasochist attempts to compile and link the software on the target board. That is to say , yes you CAN find a compiler that works within the memory of your arm board , but why would you compile on a single processor system running at a few hundred MHZ , when you can cross compile on a multi core/ multiprocessor Intel machine. 5. USE a NFS where possible, do not attempt to continually "flash" your board Nand/Nor ram. If you really must, then use SD cards to transfer between systems. 6. Golden rule....... use GIT or some other development warehouse (Subversion, CVS, whatever) 7. for long term sanity don't "hack" , any moron or kindergardener can hack, only a true pro writes software for the future (that is not to say you cannot hack as a quick test, but long term it is usually a bad idea) 8. what ever you do, document correctly, if you "hack" the kernel use a standard searchable term to identify your hacks.
[Quote] only a madman or sadomasochist attempts to compile and link the software on the target board [/Quote] Oh yes ! There is not much advantages to do that. What I understand is : doing it via cross compiling and not OpendEmbedded / BuildRoot tools Thanks for answering Bob.
