Hello, i have a problem with 256MB version. After installing a new kernel which works fine on the 64MB and 128MB version and another root filesystem, also from the 128 MB version, the system kills the supervivi on halt or reboot. I installed supervivi 128 MB with DNW then the kernel then the imagefile then switched off, and on, system works then i type in "halt" at the console, and the system dies. when i switch it off an on again, it does not start. After downloading supervivi 128, it works when i switch it off and on, it is ok, problem is only when the system makes a reboot or halt. I tested with the original system of the 256 MB board, no problem Can anybody help?
