This is my first time dealing with the mini2440. I am currently using qt designer to create an app for the mini2440. However I can't seem to install it or run it on the mini. What are the steps that I need to take to copy the necessary files over and to install/run it? Thanks for the help in advance.
Creating app for mini2440
Maybe you could use Qt Script. The advantage of scripts is, that they doesn't need to be compiled with a cross compiler or so (thats good if you change many things - you don't need to recompile again and again). But a working, cross compiled Qt with interpreter must be installed on mini2440.
