Hello, Currently for a college project, I'm developing an application that needs read input from the GPIOs but I'm stuck with that!! I already know how to use the UART ports but I have no idea of how to use the GPIOs. Currently I'm coding in C#, but if any of you have any example for how to use the GPIOs in c++, I could simply start again in c++!! Please any help with this would be greatly appreciated!!
Help using GPIOs
extern "C" BOOL VirtualCopy(LPVOID dest, LPVOID src, DWORD size, DWORD
flags);
typedef struct {
unsigned int rGPACON; // 00
unsigned int rGPADAT;
unsigned int rPAD1[2];
unsigned int rGPBCON; // 10
unsigned int rGPBDAT;
unsigned int rGPBUP;
unsigned int rPAD2;
unsigned int rGPCCON; // 20
unsigned int rGPCDAT;
unsigned int rGPCUP;
unsigned int rPAD3;
unsigned int rGPDCON; // 30
unsigned int rGPDDAT;
unsigned int rGPDUP;
unsigned int rPAD4;
unsigned int rGPECON; // 40
unsigned int rGPEDAT;
unsigned int rGPEUP;
unsigned int rPAD5;
unsigned int rGPFCON; // 50
unsigned int rGPFDAT;
unsigned int rGPFUP;
unsigned int rPAD6;
unsigned int rGPGCON; // 60
unsigned int rGPGDAT;
unsigned int rGPGUP;
unsigned int rPAD7;
unsigned int rGPHCON; // 70
unsigned int rGPHDAT;
unsigned int rGPHUP;
unsigned int rPAD8;
unsigned int rMISCCR; // 80
unsigned int rDCKCON;
unsigned int rEXTINT0;
unsigned int rEXTINT1;
unsigned int rEXTINT2; // 90
unsigned int rEINTFLT0;
unsigned int rEINTFLT1;
unsigned int rEINTFLT2;
unsigned int rEINTFLT3; // A0
unsigned int rEINTMASK;
unsigned int rEINTPEND;
unsigned int rGSTATUS0; // AC
unsigned int rGSTATUS1; // B0
unsigned int rGSTATUS2; // B4 ;;; SHL
unsigned int rGSTATUS3; // B8
unsigned int rGSTATUS4; // BC
unsigned int rFLTOUT; // C0
unsigned int rDSC0;
unsigned int rDSC1;
unsigned int rMSLCON;
unsigned int rGPJCON; // D0
unsigned int rGPJDAT;
unsigned int rGPJUP;
unsigned int rPAD9;
}IOPreg;
typedef struct {
unsigned int rADCCON; //ADC control
unsigned int rADCTSC; //ADC touch screen control
unsigned int rADCDLY; //ADC start or Interval Delay
unsigned int rADCDAT0; //ADC conversion data 0
unsigned int rADCDAT1; //ADC conversion data 1
unsigned int rADCUPDN; //Stylus Up/Down interrupt status
}ADCreg;
#define IOP_BASE 0xB1600000 // 0x56000000
#define ADC_BASE 0xB1800000 // 0x58000000
volatile IOPreg *m_p2440IOP;
volatile ADCreg *m_p2440ADC;
void CALLBACK RegInit(void)
m_p2440IOP = (volatile IOPreg *)
VirtualAlloc(0,sizeof(IOPreg),MEM_RESERVE, PAGE_NOACCESS);
VirtualCopy((PVOID)m_p2440IOP,(PVOID)(IOP_BASE),sizeof(IOPreg),PAGE_READWRITE|P
AGE_NOCACHE);
m_p2440ADC = (volatile ADCreg *)
VirtualAlloc(0,sizeof(ADCreg),MEM_RESERVE, PAGE_NOACCESS);
VirtualCopy((PVOID)m_p2440ADC,(PVOID)(ADC_BASE),sizeof(ADCreg),PAGE_READWRITE|P
AGE_NOCACHE);
int CALLBACK ReadAdc(int ch)
m_p2440ADC->rADCCON = (1<<14)|(20<<6)|(ch<<3); //setup channel
m_p2440ADC->rADCCON|=0x1; //start ADC
while(m_p2440ADC->rADCCON&0x1); //check if Enable_start is low
while(!(m_p2440ADC->rADCCON&0x8000)); //check if EC(End of Conversion)
flag is high
return ((int)m_p2440ADC->rADCDAT0 & 0x3ff);
int CALLBACK ReadKey(void)
int key=0;
if(m_p2440IOP->rGPGDAT&1) key|=1;
if(m_p2440IOP->rGPGDAT&8) key|=2;
if(m_p2440IOP->rGPGDAT&32) key|=4;
if(m_p2440IOP->rGPGDAT&64) key|=8;
if(m_p2440IOP->rGPGDAT&128) key|=16;
if(m_p2440IOP->rGPGDAT&2048) key|=32;
key^=0x3f;
return key;
Hello Mutzev, I tried to use the above example and modified little bit to use the GPF (EINT0-EINT4) pins on GPIO but was not successful in toggling them. I tried to configure them as output. Do you have any idea? Thanks.
Hello matt_Damon,
#define SetBit(x,y) (*(x)|=(1<<y))
#define ClrBit(x,y) *(x)=*(x)&~(1<<y)
#define ClrPin(x,y) (*(x)|=(1<<y))
#define SetPin(x,y) *(x)=*(x)&~(1<<y)
typedef struct {
unsigned int rPAD2;
unsigned int rPAD3;
unsigned int rPAD4;
unsigned int rPAD5;
unsigned int rPAD6;
unsigned int rPAD7;
unsigned int rPAD8;
unsigned int rDSC0;
unsigned int rDSC1;
unsigned int rPAD9;
}IOPreg;
void CALLBACK Init(void)
// init GPIO
m_p2440IOP = (volatile IOPreg *) VirtualAlloc(0,sizeof(IOPreg),MEM_RESERVE,
PAGE_NOACCESS);
VirtualCopy((PVOID)m_p2440IOP,(PVOID)(IOP_BASE),sizeof(IOPreg),PAGE_READWRITE|PA
GE_NOCACHE);
// make led output 01
ClrBit(&m_p2440IOP->rGPBCON,17);
SetBit(&m_p2440IOP->rGPBCON,16);
ClrBit(&m_p2440IOP->rGPBCON,15);
SetBit(&m_p2440IOP->rGPBCON,14);
ClrBit(&m_p2440IOP->rGPBCON,13);
SetBit(&m_p2440IOP->rGPBCON,12);
ClrBit(&m_p2440IOP->rGPBCON,11);
SetBit(&m_p2440IOP->rGPBCON,10);
void CALLBACK SetLed(int xled)
if(xled&1) SetPin(&m_p2440IOP->rGPBDAT,5); else
ClrPin(&m_p2440IOP->rGPBDAT,5);
if(xled&2) SetPin(&m_p2440IOP->rGPBDAT,6); else
ClrPin(&m_p2440IOP->rGPBDAT,6);
if(xled&4) SetPin(&m_p2440IOP->rGPBDAT,7); else
ClrPin(&m_p2440IOP->rGPBDAT,7);
if(xled&8) SetPin(&m_p2440IOP->rGPBDAT,8); else
ClrPin(&m_p2440IOP->rGPBDAT,8);
return;
void CALLBACK alabala(void)
static int led=0;
Init();
led=1;
SetLed(led);
led=2;
SetLed(led);
led=4;
SetLed(led);
led=8;
SetLed(led);
led=0x0f;
SetLed(led);
led=0;
SetLed(led);
Sleep(1000);
Hello Mutzev, The above program works great for setting any pin. However, how can we configure them as input and read their values? I believe we should use Clrbit function instead of setbit to configure as input. But how will we read the value? Do we need to disable pull-up resistor for pins? Thanks.
Hello Mutzev,
In the first example of Key Press,
int key=0;
key^=0x3f;
return key;
I always receiving 16, indicating that KEY5 is pressed. I verified this
using a multimeter. Can we clear this pin so that it outputs 0 when no pin
is pressed?
Thanks.
Hello Mutzev,
I tried to use the GPIO pins as input but some of the pis are allways High!
Can you please let me know what I am doing wrong?? Here is the modified
code which I am using:
#include <windows.h>
#define DLLEXPORT __declspec(dllexport)
#define EXTERNC extern "C"
EXTERNC BOOL VirtualCopy(LPVOID dest, LPVOID src, DWORD size, DWORD flags);
typedef struct {
unsigned int rPAD2;
unsigned int rPAD3;
unsigned int rPAD4;
unsigned int rPAD5;
unsigned int rPAD6;
unsigned int rPAD7;
unsigned int rPAD8;
unsigned int rDSC0;
unsigned int rDSC1;
unsigned int rPAD9;
}IOPreg;
EXTERNC DLLEXPORT void RegInit(void);
void RegInit(void)
AGE_NOCACHE);
ClrBit(&m_p2440IOP->rGPFCON,0xF);
ClrBit(&m_p2440IOP->rGPFCON,0xE);
ClrBit(&m_p2440IOP->rGPFCON,0xD);
ClrBit(&m_p2440IOP->rGPFCON,0xC);
ClrBit(&m_p2440IOP->rGPFCON,0xB);
ClrBit(&m_p2440IOP->rGPFCON,0xA);
ClrBit(&m_p2440IOP->rGPFCON,9);
ClrBit(&m_p2440IOP->rGPFCON,8);
ClrBit(&m_p2440IOP->rGPFCON,7);
ClrBit(&m_p2440IOP->rGPFCON,6);
ClrBit(&m_p2440IOP->rGPFCON,5);
ClrBit(&m_p2440IOP->rGPFCON,4);
ClrBit(&m_p2440IOP->rGPFCON,3);
ClrBit(&m_p2440IOP->rGPFCON,2);
ClrBit(&m_p2440IOP->rGPFCON,1);
ClrBit(&m_p2440IOP->rGPFCON,0);
EXTERNC DLLEXPORT int ReadKey(void);
int ReadKey(void)
int key=0;
if(m_p2440IOP->rGPFDAT&1) key|=1;
if(m_p2440IOP->rGPFDAT&2) key|=2;
if(m_p2440IOP->rGPFDAT&4) key|=3;
if(m_p2440IOP->rGPFDAT&8) key|=4;
if(m_p2440IOP->rGPFDAT&16) key|=5;
if(m_p2440IOP->rGPFDAT&32) key|=6;
if(m_p2440IOP->rGPFDAT&64) key|=7;
if(m_p2440IOP->rGPFDAT&128) key|=8;
key^=0xff;
return key;
Thanks.
Colleague, what you doing this? ... ClrBit(&m_p2440IOP->rGPFCON,0xF); ClrBit(&m_p2440IOP->rGPFCON,0xE); ClrBit(&m_p2440IOP->rGPFCON,0xD); ClrBit(&m_p2440IOP->rGPFCON,0xC); ClrBit(&m_p2440IOP->rGPFCON,0xB); ClrBit(&m_p2440IOP->rGPFCON,0xA); ClrBit(&m_p2440IOP->rGPFCON,9); ClrBit(&m_p2440IOP->rGPFCON,8); ClrBit(&m_p2440IOP->rGPFCON,7); ClrBit(&m_p2440IOP->rGPFCON,6); ClrBit(&m_p2440IOP->rGPFCON,5); ClrBit(&m_p2440IOP->rGPFCON,4); ClrBit(&m_p2440IOP->rGPFCON,3); ClrBit(&m_p2440IOP->rGPFCON,2); ClrBit(&m_p2440IOP->rGPFCON,1); ClrBit(&m_p2440IOP->rGPFCON,0); ....
1. Must read guide to s3c2440. Page 263. 2. Misunderstanding what is the problem. When you configure ports as input it in set to 1 and becomes 0 at press. If You want pressed key=1 use the XOR (key ^ 0xff). .... int key=0; if(m_p2440IOP->rGPGDAT&1) key|=1; ..... if(m_p2440IOP->rGPGDAT&0x80) key|=0x80; key^=0xff; 3. If you want to do all of the pins as inputs GPF is not it easier instead to use just above m_p2440IOP-> rGPFCON = 0, or if you want set to output m_p2440IOP-> rGPFCON = 0haa; aa (hex) = 10 10 10 10 4. Possibly due to bad my english misunderstood what you ask for which I apologize.
Hello Mutzev, I was using Clrbit function to set GPFCON register to input on all pins. Then I am using the GPFDAT function to read the values of respective pin values on the GPIO port. The 6 Key press is working fine now. But GPFDAT on the GPIO port are not working.
"The 6 Key press is working fine now. But GPFDAT on the GPIO port are not working." if it works, what does not work?! See whether the F PORT was finally correctly as input. See also register GPFUP
Hello mutzev,
Here is the code which I am using. The vale of "key" is 240. I expected
it to be 0 when nothing is connected to the GPF pins. I checked the GPFCON
and GPFUP values. They are 0:
GE_NOCACHE);
m_p2440IOP->rGPFCON = 0; //to set GPF to input
m_p2440IOP->rGPFUP = 0; //disable pullups
int ReadKey(void)
int key=0;
//key=m_p2440IOP->rGPFUP; This is to check GPFUP value
//key=m_p2440IOP->rGPFCON; This is to check GPFCON value
key^=0xff;
return key;
// incorect ... if(m_p2440IOP->rGPFDAT&1) key|=1; if(m_p2440IOP->rGPFDAT&2) key|=2; if(m_p2440IOP->rGPFDAT&4) key|=3; if(m_p2440IOP->rGPFDAT&8) key|=4; if(m_p2440IOP->rGPFDAT&16) key|=5; if(m_p2440IOP->rGPFDAT&32) key|=6; if(m_p2440IOP->rGPFDAT&64) key|=7; if(m_p2440IOP->rGPFDAT&128) key|=8; .... // corect ... if(m_p2440IOP->rGPFDAT&1) key|=1; if(m_p2440IOP->rGPFDAT&2) key|=2; if(m_p2440IOP->rGPFDAT&4) key|=4; if(m_p2440IOP->rGPFDAT&8) key|=8; if(m_p2440IOP->rGPFDAT&16) key|=16; if(m_p2440IOP->rGPFDAT&32) key|=32; if(m_p2440IOP->rGPFDAT&64) key|=64; if(m_p2440IOP->rGPFDAT&128) key|=128; .... or try this key = (m_p2440IOP->rGPFDAT)^0xff;
Hello mutzev,
The following code works! I am not sure what I was doing wrong before.
Using this I was able to use GPIO pins as input and output:
//#include "stdafx.h"
//#include "Pkfuncs.h"
//#include "s2440.h" //In some BSPs this file has a slightly different
name
//#include <time.h>
//#include <ceddk.h>
void gpioInit();
void Virtual_Alloc();
typedef struct {
unsigned int rPAD2;
unsigned int rPAD3;
unsigned int rPAD4;
unsigned int rPAD5;
unsigned int rPAD6;
unsigned int rPAD7;
unsigned int rPAD8;
unsigned int rDSC0;
unsigned int rDSC1;
unsigned int rPAD9;
}IOPreg;
bool memoryAlloced = false;
volatile IOPreg *s2440IOP = (IOPreg *)IOP_BASE;
EXTERNC DLLEXPORT bool DLLreadPin(int port, int pin);
gpioInit();
switch (port) {
case 0:
if (s2440IOP->rGPADAT & (0x1 << pin))
return true;
else
return false;
break;
case 1:
if (s2440IOP->rGPBDAT & (0x1 << pin))
return true;
else
return false;
break;
case 2:
if (s2440IOP->rGPCDAT & (0x1 << pin))
return true;
else
return false;
break;
case 3:
if (s2440IOP->rGPDDAT & (0x1 << pin))
return true;
else
return false;
break;
case 4:
if (s2440IOP->rGPEDAT & (0x1 << pin))
return true;
else
return false;
break;
case 5:
if (s2440IOP->rGPFDAT & (0x1 << pin))
return true;
else
return false;
break;
case 6:
if (s2440IOP->rGPGDAT & (0x1 << pin))
return true;
else
return false;
break;
return false;
EXTERNC DLLEXPORT int DLLmakeInputPin(int port, int pin);
gpioInit();
switch (port) {
case 0:
s2440IOP->rGPACON = (s2440IOP->rGPACON &~ ( 3 << pin*2)) ;
break;
case 1:
s2440IOP->rGPBCON = (s2440IOP->rGPBCON &~ ( 3 << pin*2)) ;
break;
case 2:
s2440IOP->rGPCCON = (s2440IOP->rGPCCON &~ ( 3 << pin*2)) ;
break;
case 3:
s2440IOP->rGPDCON = (s2440IOP->rGPDCON &~ ( 3 << pin*2)) ;
break;
case 4:
s2440IOP->rGPECON = (s2440IOP->rGPECON &~ ( 3 << pin*2)) ;
break;
case 5:
s2440IOP->rGPFCON = (s2440IOP->rGPFCON &~ ( 3 << pin*2)) ;
break;
case 6:
s2440IOP->rGPGCON = (s2440IOP->rGPGCON &~ ( 3 << pin*2)) ;
break;
return 0;
EXTERNC DLLEXPORT int DLLsetPin(int port, int pin, bool on);
gpioInit();
switch (port) {
case 0:
s2440IOP->rGPACON = (s2440IOP->rGPACON &~ ( 3 << pin*2)) | ( 1<< pin*2);
if (!on)
s2440IOP->rGPADAT = (s2440IOP->rGPADAT &~ (0x1 << pin));
else
s2440IOP->rGPADAT = (s2440IOP->rGPADAT | (0x1 << pin));
break;
case 1:
s2440IOP->rGPBCON = (s2440IOP->rGPBCON &~ ( 3 << pin*2)) | ( 1<< pin*2);
if (!on)
s2440IOP->rGPBDAT = (s2440IOP->rGPBDAT &~ (0x1 << pin));
else
s2440IOP->rGPBDAT = (s2440IOP->rGPBDAT | (0x1 << pin));
break;
case 2:
s2440IOP->rGPCCON = (s2440IOP->rGPCCON &~ ( 3 << pin*2)) | ( 1<< pin*2);
if (!on)
s2440IOP->rGPCDAT = (s2440IOP->rGPCDAT &~ (0x1 << pin));
else
s2440IOP->rGPCDAT = (s2440IOP->rGPCDAT | (0x1 << pin));
break;
case 3:
s2440IOP->rGPDCON = (s2440IOP->rGPDCON &~ ( 3 << pin*2)) | ( 1<< pin*2);
if (!on)
s2440IOP->rGPDDAT = (s2440IOP->rGPDDAT &~ (0x1 << pin));
else
s2440IOP->rGPDDAT = (s2440IOP->rGPDDAT | (0x1 << pin));
break;
case 4:
s2440IOP->rGPECON = (s2440IOP->rGPECON &~ ( 3 << pin*2)) | ( 1<< pin*2);
if (!on)
s2440IOP->rGPEDAT = (s2440IOP->rGPEDAT &~ (0x1 << pin));
else
s2440IOP->rGPEDAT = (s2440IOP->rGPEDAT | (0x1 << pin));
break;
case 5:
s2440IOP->rGPFCON = (s2440IOP->rGPFCON &~ ( 3 << pin*2)) | ( 1<< pin*2);
if (!on)
s2440IOP->rGPFDAT = (s2440IOP->rGPFDAT &~ (0x1 << pin));
else
s2440IOP->rGPFDAT = (s2440IOP->rGPFDAT | (0x1 << pin));
break;
case 6:
s2440IOP->rGPGCON = (s2440IOP->rGPGCON &~ ( 3 << pin*2)) | ( 1<< pin*2);
if (!on)
s2440IOP->rGPGDAT = (s2440IOP->rGPGDAT &~ (0x1 << pin));
else
s2440IOP->rGPGDAT = (s2440IOP->rGPGDAT | (0x1 << pin));
break;
return 0;
// GPIO Virtual alloc
s2440IOP = (volatile IOPreg *) VirtualAlloc(0,sizeof(IOPreg),MEM_RESERVE,
PAGE_NOACCESS);
if(s2440IOP == NULL)
RETAILMSG(1,(TEXT("For s2440IOP: VirtualAlloc faiLED!\r\n")));
else {
if(!VirtualCopy((PVOID)s2440IOP,(PVOID)(IOP_BASE),sizeof(IOPreg),PAGE_READWRITE
| PAGE_NOCACHE ))
RETAILMSG(1,(TEXT("For s2440IOP: VirtualCopy faiLED!\r\n")));
void gpioInit() {
if (!memoryAlloced)
Virtual_Alloc();
memoryAlloced = true;
|=OR 1|2|3=3 1|2=3 1|2|3|4|5|6|7|8=15=0x0f... 0x0f^ff=240... 1|2|4|8|16|32|64|128=0xff ... 0xff^0xff=0....
I assume you meant . . . any other way of doing this in C. There is nothing special about "C, under Linux". Have a look at these: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&... http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewforum&... Fortunately the same compiler (GCC) is used for both. What can make a difference is the device architecture (Havard versus von Neumann). The AVR devices referred to here are Harvard. Some macro definitions for ports, as far as I understand, may not work for both. More investigation required! Good luck.
And by Linux, I meant in C targeted towards mini2440 running a Linux OS, not using windows.h header.
You are in the wrong forum/topic (WinCE). Search in the Linux forum for "GPIO". If you want direct access to the GPIO registers then its also nearly the same under WinCE and Linux...
I tried to compile this dll... but I have this error: Error 4 error LNK2019: unresolved external symbol _VirtualCopy referenced in function "void __cdecl Virtual_Alloc(void)" (?Virtual_Alloc@@YAXXZ) gpio_arm.obj can someone send me the compiled DLL or upload it here (jeangr@alice.it)?
I tried to compile this dll... but I have this error: Error 4 error LNK2019: unresolved external symbol _VirtualCopy referenced in function "void __cdecl Virtual_Alloc(void)" (?Virtual_Alloc@@YAXXZ) gpio_arm.obj can someone send me the compiled DLL or upload it here (info@edgsistemi.it)?
You can find a Wince 6 GPIO driver on my website (http://www.domodom.fr/spip/A-GPIO-driver-for-mini2440.html?lang=en), with c++, c# and VB.net samples. domodom
Hi everybody I have been using S3C2440 Micro2440 for WINCE 5.0, but I can't find GPIO driver in regedit of Board. How I can load GPIO driver into this board. Please instruct me. Thanks a lot
If you're using CE5, there's no need to use DLLs specifically to access the
I/O pins from C#
It can be done directly from the C# code, without any need for P/Invoking
DLLs written in C.
e.g. ( a snippet)
unchecked
unsafe
IOP_BASE = new IntPtr((void*)0xB1600000UL);
lpv = VirtualAlloc(IntPtr.Zero,
(UInt32)Marshal.SizeOf(Registers), MemUsageFlags.MEM_RESERVE,
PageAccessFlags.PAGE_NOACCESS);
bRet = VirtualCopy(lpv, IOP_BASE,
(UInt32)Marshal.SizeOf(Registers), PageAccessFlags.PAGE_READWRITE |
PageAccessFlags.PAGE_NOCACHE);
unsafe
GPIOReg = (IOPReg*)lpv;
you can then just use it as you would a C structure. e.g.
unsafe
GPIOReg->aregister = avalue;
Basically C# allows the use of pointers provided you use them in an unsafe
context.
