I just got a MINI2440 and I can navigate the web with Konqueror but only the NETACT green LED lights. The NETLINK yellow LED remains off all the time. According to the schematic both LEDs are connected and should light, right? Does anyone have the same problem?
LEDs in the RJ45 ethernet connector
Yep, the yellow LED is definitely bad. One day since I got the board from ESKY-SH and below are the problems I found so far: - jammed ON/OFF switch (I have to turn the board ON/OFF by inserting/removing the adaptor plug) - non functional yellow LED in the RJ45 connector - SDRAM chips with suspect strikethroughs over their texts Who knows what else...
Hi Renato, Are you using a 10Mb ethernet network? The Link led only lights on a 100Mb network... We all(?) have the strikethroughs over the ram. The switch is a problem though... Thanks, Errol
Hello Errol, Yes, I am using a 100Mbps ethernet. In fact I know the yellow LED is dead because when I connect a spare one in parallel it lights up just fine. Thanks for your feedback. Best Regards, Renato
