start my application
sherry 2010-06-01 12:54:55 Link
Dear All,
  I want to boot my application (Example yy2) automatically once the power
is switched on without any user interface or without logging.
Jon Ambrose 2010-06-01 14:28:09 Link
During bootup it would be /etc/rc.local or a startup
script in /etc/init.d with links in the /etc/rc.d/rcX.d directories
and only run during boot up or runlevel changes.
sherry 2010-06-02 07:46:21 Link
Thanks Jon
can you please elaborate the procedure above u said with an example....
it will be great support if u help me.
Jon Ambrose 2010-06-02 10:56:54 Link
I will have alook tonight when I have my board in front of me.
What I said above was generic for Linux machines. It may be that its
slightly different on the Mini2440.
sherry 2010-06-03 07:01:25 Link
Actually I tried to put my application in rc.local file and rebooted the
board it booted normally but my application did not pop up???
I want to try by putting script file in /etc/init.d and link with
/etc/rc2.d  but I am confused what should be written in script file...
please any one has ready script it will be great help to me.
davef 2010-06-03 07:54:10 Link
Have you got an & at the end of the command line?
Look in the factory distro /etc/init.d/rcS for an example and the last line
when it boots up Qtopia.
sherry 2010-06-03 09:01:31 Link
thanks davef,
 yes but where exactly I should do modification can please give any ready
available script.
 one thing where should  I copy my a.out file in target(mini2440) board
I mean i did it in /home
sherry 2010-06-03 09:15:49 Link
Dear Devef,
suppose I have following appache.sh file in /etc/init.d
now I want to modify this script file for my application for example yy
please will you tell me how to and where to modify in this file
#!/bin/bash
# apache-ssl    Start the apache-ssl HTTP
# The variables below are NOT to be changnetd
# script more readable.
                                         ll
NAME=apache-ssl
DAEMON=/usr/sbin/$NAME
PIDFILE=/var/run/$NAME.pid               --exec $DAEMON > /dev/null
CONF=/etc/$NAME/httpd.conf
APACHECTL=/usr/sbin/${NAME}ctl
# note: SSD is required only at startup o
SSD=`which start-stop-daemon`
ENV="env -i LANG=C PATH=/bin:/usr/bin:/us
                                         dfile $PIDFILE --signal HUP; then
trap "" 1                                ILE --exec $DAEMON > /dev/null
# Check that we're not being started by i
if egrep -q -i "^[[:space:]]*ServerType[[
then
    exit 0
|stop|reload|reload-modules|force-reloa
fi
est_config() {
    if [ ! -x $APACHECTL ]; then
        echo "$APACHECTL is not executable, exiting"
        exit 0
    fi
    # ensure we don't leak environment vars into apachectl
    APACHECTL="$ENV $APACHECTL"
    if ! $APACHECTL configtest 2> /dev/null
    then
        printf "Configuration syntax error detected. Not reloading.\n\n"
        exit 1
    fi
should_start() {
    if [ ! -x $DAEMON ]; then
        echo "apache-ssl is not executable, not starting"
        exit 0
    fi
case "$1" in
  start)
    should_start
    test_config
    echo -n "Starting web server: $NAME"
    $ENV $SSD --start --pidfile $PIDFILE --exec $DAEMON > /dev/null
  stop)
    echo -n "Stopping web server: $NAME"
    start-stop-daemon --stop --pidfile $PIDFILE --oknodo
    rm -rf /var/lib/apache/mod-bandwidth/link/*
  reload | force-reload)
    test_config
    echo -n "Reloading $NAME configuration"
    start-stop-daemon --stop --pidfile $PIDFILE --signal USR1
  reload-modules)
    test_config
   echo -n "Reloading $NAME modules"    IDFILE --oknodo --retry 30
    should_start                         --exec $DAEMON > /dev/null
  restart)
    test_config
    echo -n "Restarting $NAME"           dfile $PIDFILE --signal HUP; then
    if ! start-stop-daemon -q --stop --piILE --exec $DAEMON > /dev/null
    fi
    echo "Usage: /etc/init.d/$NAME
{start|stop|reload|reload-modules|force-reloa
d|restart}"
    exit 1
esac
if [ $? -eq 0 ]; then
        echo .
        exit 0
else
        echo " failed"
        exit 1
fi
davef 2010-06-03 10:37:22 Link
Sorry, but you quickly exceeded my knowledge limits!
To start Qtopia on the factory distro:
/bin/Qtopia &
Someone will have to help.
Good luck!
sherry 2010-06-04 13:21:48 Link
Hey I got it...
my application in booting once power is switched on
Jon Ambrose 2010-06-04 15:08:18 Link
Nice!
Sorry I didn't have time to look into it.
What was the solution?
david 2010-08-30 18:43:27 Link
hi, i have the same problem, how did you make it??
Tom 2010-08-30 19:09:16 Link
You must add starting script to rcS. In script You must export all needed
environment variables and then run application.
best regards
Tom
david 2010-09-10 16:40:42 Link
hi Tom i tried what you told me, on file rcS i put this line:
/home/cherokee/sbin/./cherokee with this my webserver started automatic,
but my system couldnt start. i saw the system's proccess by my host compute
(by hyperterminal) and it seems that it started cherokee, but it didnt
continue with the others proccess.
what could i did wrong?
i hope you can helpme, thanks alot !!
david 2010-09-10 18:58:54 Link
excuseme this was the exactly command line i used:
/home/cherokee/sbin/cherokee start
david 2010-09-13 15:30:27 Link
thanks to davef the solution was:
/home/cherokee/sbin/cherokee start &
Reply
Name
eMail (not visible)
Text
Please enter the number 6661
