Helllo, Ok just updated my mini2440 with latest supervivi through jtag. Loaded new N-Boot N35 and windows ce 6.0 build for N35. It loads fine and everythings all good however it seems that the touch on the display is flipped. So when i select top left it selects start menu which is of course bottom left? Is there easy fix/setting? Something not set right? Any Help Appreciated... Z..
Touch Screen Flipped CE6
Hello All, If anyone has the solution for the above problem please let me know. Even I am facing the same problem.
Alfred Angelo Designer Wedding Dress is very popular among Europe and the Unite States.Alfred Angelo was founded in the mid-1930s by the husband and wife team of Alfred Angelo and Edythe Piccione. With Edythe’s unique and popular designs, and Alfred’s knack for high quality manufacturing, the company quickly became the leading manufacturer in the US bridal industry. Shortly after, the company expanded its distribution to hundreds of stores throughout the UK and mainland Europe, Canada, Australia and New Zealand. [url=http://www.goodgoodschina.com/categories/clothing-apparel/party-dresses]... party dresses[/url]
I had the same problem. first try to start the calibration app from control panel. If it doesn't end calibrating, it's a problem with the connection between LCD an the board. Try to push the connection tape deeper in the slot.
Hello elcrazburro, thank you for the suggestion, I am able to run the calibration app from control panal. When I run this application I get a cursor (+) which will move to all 4 coordinates when I touch the touch screen. I am not able to exit from this application using mouse nor the board is calibrated when I power on and off the system. Please let me know where am I going wrong. Thank you.
