I have built my own file system and I am using u-boot ( JFFS nand partition ). However, I would like to get the QT provided in official RFS Yaffs2 image on this website. So I would like to mount the yaffs2 image without flashing any NAND or use SDCARD. I try this wihtout success : [root@mini2440 /]# losetup root_qtopia-128M.img /dev/loop/loop1 losetup: root_qtopia-128M.img [root@mini2440 /]# [root@mini2440 /]# mount -o loop /dev/loop/loop1 /tmp/sd/ mount: mounting /dev/loop/loop1 on /tmp/sd/ failed: Invalid argument [root@mini2440 /]# mount /dev/loop/loop1 /tmp/sd/ mount: mounting /dev/loop/loop1 on /tmp/sd/ failed: Invalid argument Anyone can help ? Thank a lot
Read YAFFS image using loop device
it posible but not under loopback device install mtd-tools or mtd-utils and try those modprobe mtd modprobe jffs2 modprobe mtdram modprobe mtdchar modprobe mtdblock after that ,will be a device at /dev/mtdblock0 dd if=your_image_jffs2 of=/dev/mtdblock0 make a folder, ex. mkdir /mnt/mtd mount -t jffs2 /dev/mtdblock0 /mnt/mtd
I thought u-boot could only load uImages and Supervivi only load zImages. Or is there something happening here that I don't understand about loopback?
Thank for answer In fact, I would like to mount the YAFFS ( not JFFS2) on mini2440 and not my computer ( Under Ubuntu, YAFFS is not support by kernel I suppose )
hi , i've used this tool to extract the image -not mount it- , and it working on ubuntu 10.10 http://www.google.com/url?sa=D&q=http://code.google.com/p/yaffs2utils/
