Hi all, I bought this board a few days ago and i'm having some trouble to restore the default Qtopia image that a got from the shipped CD. I would like to boot QTopia from u-boot and not use vivi. I'm new in this embedded world and really need some help. I have a mini2440 128M. Files used: u-boot-128M.bin uImage root_qtopia-128M.img I can load u-boot on the NAND, also downloaded the kernel uImage and got no errors. When a i try to download the root_qtopia-128M.img from SD it gets stuck. MINI2440 # fatload mmc 0:1 0x31000000 root_qtopia-128M.img reading root_qtopia-128M.img <--- stuck here I followed the steps on the link below but insted of using GPE i tried QTopia because the link that points to the binarys for this tutorial seems to be broken. http://narnia.cs.ttu.edu/drupal/node/131 Would help if anyone could send me some images that works, just for me to test the procedure of changing the environment. Many thanks in advance.
u-boot and qtopia on NAND
you have tu install the yaffs image by supervivi.. but you need a uImage of your kernel if you want to boot with u-boot
Thanks klom for the reply. So i have to download the root_qtopia-128M.img by vivi? [y] Download root_yaffs image Is there a way to do this by u-boot? what about the kernel? Could it be the uImage i already installed by u-boot or do i have to install a new zImage_N35(example) also by vivi? I know this is probably a basic question but i really need something to start with. Thanks..
