I managed to boot a 2.6.31 kernel on my mini2440 (the 64 MB NAND version). However, after I patched it with Xenomai or Real Time, the boot process stops at setting the frequency of the MMC host controller. This is what I get: [ 2.535000] Registered led device: led1 [ 2.535000] Registered led device: led2 [ 2.540000] Registered led device: led3 [ 2.540000] Registered led device: led4 [ 2.545000] s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). [ 2.550000] Registered led device: backlight [ 2.565000] s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). A workable kernel displays a 16 MHz running frequency on the controller and the booting process continues without glitches. Is there any user who had this problem before? Is there a patch available? I would be extremely grateful if someone posted a solution to this. Thank you.
Boot freezes after Xenomai or Real Time Patch
Been there, done that. The problem is I want to have mmc capable kernel. I even made a diff between the mmc related file of the workable and non-bootable kernels. They are identical. So the problem is somewhere else. just my 2 cents...
The problum is with serial driver try to recomile it with X**** support. I had same problum with RTAI on some other board.
