Hi, First, I am quite new with linux but I have very good knowledge of embedded programming. I managed to build a nice GUI with Qt embedded 4. Now I would like to have it starting up automatically when Mini2440 device boots. I did some research on init sequence of linux. Everywhere there are notes about /etc/inittab but I can't find this file on my device ? Why ? How can linux boot successfuly without this file ? I tried to add my executable in the rcS file. The program fires at boot but the touchscreen is not responding. This is because I need to export some variables before executing the program. I added the export lines in /etc/profile. When I kill the application and restart it manually, the touchscreen works. This tells me that the rcS file is executed before the profile variables are exported... am I right ? If so, how can I launch ma program at the total END of init of linux kernel ? Thanks for the help
Linux init
Hi, thanks for replying. On the last line of my rcS file I add the following lines: (my app is AVDistGui) cd /home/AVDist ./AVDistGui -qws -display transformed:Rot90 & In theory this works... it does if I enter manually. As I said, the program launches but without touchscreen... It's very wierd. Thanks in advance for helping.
Ok, I figured some things out. /etc/profile contains systemwide definitions, such as environment variables but it is "executed" only when a user logs in. /etc/init.d/rcS is executed on linux initialization but I tried to export environment variables without success. I got two questions: - Is it possible to have environment variables exported without having a user logged-in ? - If not, is it possible to have some kind of auto-login that would login a user automatically at boot and run /etc/profile and fire my app automatically with the touchscreen environment variables enabled. Thanks to anyone who can help.
Finally. I found the solution. For those interested, if you wish to export environment variables, you can do it in /etc/rcS. Experience showed me that you have to do it in two parts. First declare the variable and then export it. THE_VARIABLE=blah export THE_VARIABLE I did export all my environment variables before invoking my app and everything works fine. It fires and touchscreen works. JF
You can change FriendlyARM.ini to set Linux-CommandLine,add parameter init=/sbin/init (this program is first run when kernel total END of init.
