Hi, I've been stuck on this for months, so if anyone can help me I'll be very very very very very grateful. I have cross compiled a program that edits video streaming from the s3c2440camera and outputs it to the screen. If I cross compile it using arm-linux-g++ and load it onto a mini2440 running friendlyarm's original image, then it works fine. Then I take my test mini2440, which runs the friendlyarm kernel (with the s3c2440camera as a module), and a minimal openembedded fs (a minimized version of mini2440-image). When I do this, I get the following error: /phospeep: /lib/libc.so.6: version `GLIBC_2.8' not found (required by /phospeep) /phospeep: /lib/libc.so.6: version `GLIBC_2.8' not found (required by /lib/libphos.so) So I cross compiled it with the angstrom arm compiler and although it doesn't give an error it crashes. The files libc.so.6 exist and point to libc-2.6.1.so, if I nm the libc-2.6.1.so on my desktop it says "nm: libc.so.6: no symbols". I have tried reinstalling the ipk package from the OE build by copying it across to the mini2440 and running both opkg install libc6_2.6.1-r15.1_armv4t.ipk opkg install libc6-dev_2.6.1-r15.1_armv4t.ipk But in both cases I get: root@mini2440:/# opkg install libc6_2.6.1-r15.1_armv4t.ipk Multiple packages (libc6 and libc6) providing same name marked HOLD or PREFER. Using latest. Multiple packages (libc6 and libc6) providing same name marked HOLD or PREFER. Using latest. Multiple packages (libc6 and libc6) providing same name marked HOLD or PREFER. Using latest. Installing libc6 (2.6.1-r15.1) to root... Collected errors: * Package libc6 md5sum mismatch. Either the opkg or the package index are corrupt. Try 'opkg update'. I get the feeling that there is some part of the library missing, but I can't figure out how to repair/replace it. So in other words I'm stuck. Btw, I've rebuilt about 10 mini2440 and its always the same. As I said, any help will be very much appreciated! Thanks a million
