Hello, Is there any place in .config file we need to specify the size of NAND flash? I got this question after seeing different zImage file download links on website. ~Trinath --I am new. Learning ARM9
Question: Compiling Linux kernel sources for 128MB NAND
are you trying to install qtopia on mini?? if its what you need you have to install first the vivi and after that the zimage and its depends of the size of your screan
Yes. I am trying to install Qtopia on mini2440. My question is related to compiling Linux sources only. I am trying to understand where in the kernel sources compilation process I need to specify the NAND flash size. or... is NAND Flash size really a matter for kernel compilation?
Never seen anything in .config about NAND flash size. Different types of memory, yes. The bootloader needs to be told this information when you are uploading images to the target.
