HI i already install java on mini2440 the cvm but i cant make my programs made by netbeants work, can anybody tellme what can i do, i have been doing normal java's application and java's mobiles application,but neither works. the mistake its this: java.lang.NoclassDefFoundError:javax/microedition/midlet/MIDlet What can i do?? help!!
help with java
Hmm? Can somebody tell how to get java work on mini2440??? I think java could not be installed on arm-cpu's and now i read this here. So please, can you tell what to do to get java work with linux on mini2440?
friend i have already done that use JDK 1.4, what else could be? Christopher about install java follow this links: http://translate.googleusercontent.com/translate_c?hl=es&sl=zh-CN&am... http://translate.google.ro/translate?hl=ro&sl=zh-CN&tl=en&u=...
Christopher could you install java? did it help you? im developing and java application and i would be usefull if we join jeje
Can you explain what is the error ? Did you port cvm virtual machine on mini2440 ? For me works great. I develop a web server and an application that use COMM communication. If you want to talk about porting java on mini2440 here are my contact: Skype: nicusor.popescu Y!M : p.nicusor Regards, azzido
Hello. I'm compiling the mini2440 cvm virtual machine. I have been following this steps: http://translate.google.ro/translate?hl=ro&sl=zh-CN&tl=en&u=... My problem is at the step number 8. I have modified the archive segvhandler_arch.c, lines: #define ucontext asm_ucontext #include <asm/ucontext.h> to: //#define ucontext asm_ucontext #include <ucontext.h> But not compile. Thank you. Diego.
you have to compile your file ALWAYS step on this route: /cdc/build/linux-arm-generic if you can made succesfull programs using MIDLETS can you please tellme i have have some difficulties on this
