i want to turn on and off gpio ,how can i do that in c language using evc++
i already tried hello world its working ,but if i try to do the following
its not working
#include"windows.h"
#define rGPBCON (*(volatile unsigned *)0x56000010) //Port B control
#define rGPBDAT (*(volatile unsigned *)0x56000014) //Port B data
#define rGPBUP (*(volatile unsigned *)0x56000018) //Pull-up control B
int WinMain()
int data,i;
data = 0x06;
while(1)
rGPBDAT = (data<<5);
for(i=0;i<100000;i++)
data =~data;
return 0;
iam getting an error like this illegal operation while iam trying to run in
mini 2440
pls pa anybody help.....................
Switching PORTS on and off with evc++
Hello, With Windows CE, you can't directly access registers by using their physical address. You have to declare a virtual pointer and map it to the physical address of the register(s) you want to access. Then, to access register, you use the virtual pointer. If you are under CE 5.0, it could be made directly in an application. If you are under CE 6.0, you have to use a driver. You can have a look to my tutorial, you will find a GPIO driver and a sample applcition written in c++ (http://www.domodom.fr/spip/A-GPIO-driver-for-mini2440.html). The source code of the driver is available, then you will be able to study the source code to understand how it works. domodom
Hi domdom, Iam not good in c++.pls understand but iam good in c can u give me a sample application to just turn on and off a led for wince 5 help me pls..........................pa.......................................
My driver and its sample application are written in C, so you should easily understand how it works. domodom
hi domdom,
from my early age i love to work in embedded ,but this kit
makes me frustrating can u please help me to access a port can u give me a
sample program for me that just turns on and off the ports with delay in
wince 5.0 can u spend a little time for me pls pa help me ...............
i know u are a master can u spend a little time pls ...............
Awaiting for ur reply thanks...........
pls pa somebody help pa.i beg u pls.i have to submit a project.definitely this time they are goin to fail me............................................
What don't you understand in my source code ? Did you at least took the time to study it ? I won't write your project for you ! domdom
domdom dont get angry pls this is my doubt. in vb.net i have mapped the physical address like ths Shared iADCDAT0 As New PhysicalAddressPointer(&H5800000C, &H1) in evc++ how can i map it just give me a example thats enough this is my last doubt hereafter i wont disturb u........ thanks for ur reply...............................
Look in the source code of domodom's GPIO driver: http://www.domodom.fr/spip/A-GPIO-driver-for-mini2440.html There are also code snippets in this forum, if you search for GPIO... So where is your problem!
hi
#include <windows.h>
#include <pm.h>
#include "s2440.h"
#define U32 unsigned int
volatile IOPreg *s2440IOP = (IOPreg *)IOP_BASE;
void Virtual_Alloc();
void dely(U32); // Virtual allocation
void dely(U32 tt)
U32 i;
for(;tt>0;tt--)
for(i=0;i<10000;i++){}
// GPIO Virtual alloc
s2440IOP = (volatile IOPreg *) VirtualAlloc(0,sizeof(IOPreg),MEM_RESERVE,
PAGE_NOACCESS);
int WINAPI WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPWSTR lpCmdLine, int nCmdShow)
volatile UINT32* gpxCon = 0;
volatile UINT32* gpxDat = 0;
int data;
data=0x06;
Virtual_Alloc();
gpxCon = &s2440IOP->rGPBCON;
*gpxCon=0x155555;
gpxDat = &s2440IOP->rGPBDAT;
while(1)
*gpxDat = (data<<5);
dely(120);
data =~data;
return 0;
this is my new program is this correct but iam still getting errors while
iam trying to run the exe in wince5.0
Hi domdom, hi domdom dont get angry da pls tell me, my above program is correct or not iam using mini2440 with wince5...............................
Yes, I think it's OK, but if you don't give us more explanations about your problem, I won't be able to help you. By the way, did you tried my driver in Windows CE 5 ? I think it should work... domodom
ya i tried it is not working
i also tried to write like this
#include <pm.h>
#include "s2440.h"
void dely(U32 tt)
U32 i;
for(;tt>0;tt--)
PAGE_NOACCESS);
int data;
data=0x06;
Virtual_Alloc();
2440IOP->rGPBDAT= s2440IOP->rGPBDAT & (0x1 << 5);//reading pin 5
s2440IOP->rGPBCON = (s2440IOP->rGPBCON &~ ( 3 << 5*2)) | ( 1<< 5*2);
while(1)
s2440IOP->rGPBDAT = (s2440IOP->rGPBDAT &~ (0x1 << 5));
dely(120);
s2440IOP->rGPBDAT = (s2440IOP->rGPBDAT | (0x1 << 5));
return 0;
it is also giving error pa domdom.any ideas or suggestions....
application lava.exe has performed illegal operation and will be shutdown if the problem persists contact the program vendor program:lava.exe exception:0xC0000005 address:000110E0 domdom sir is my above program is right...................... why am i getting this domdom sir thanks for helping me.........
Hi domdom,
so i have to add this line right
PAGE_NOACCESS);
if(s2440IOP == NULL) {
RETAILMSG(1,(TEXT("For s2440IOP: VirtualAlloc faiLED!\r\n")));
Hi domdom
iam going to cry domdom my usb driver is not working now.
I am having window xp2. In dnw i get this error usb not ok because i cant
install the usb driver. i tryed my computer manage->usb driver and i
installed but it is asking for SECBULK.Sys...........
ok i will addd virtual copy
also.....................................................................
I'm sorry, but I can't help you with this problem... I think that with virtualcopy, it should work domodom
PAGE_NOACCESS);
else {
if(!VirtualCopy((PVOID)s2440IOP,(PVOID)(IOP_BASE),sizeof(IOPreg),PAGE_READWRITE
| PAGE_NOCACHE )) {
RETAILMSG(1,(TEXT("For s2440IOP: VirtualCopy faiLED!\r\n")));
i included this files only
#include <pm.h>
#include "s2440.h"
i tryed to add like this but getting the following error..
C:\Documents and Settings\selva\Desktop\gpio.cpp(42) : error C2065:
'VirtualCopy' : undeclared identifier
sir am i missing any header.... sir
i resolved the problem but i didnt check it in wince because of usb problem.tommorow pls check my forum pls da domdom....... take care #define EXTERNC extern "C" EXTERNC BOOL VirtualCopy(LPVOID dest, LPVOID src, DWORD size, DWORD flags);
VirtualCopy is declared if the pkfuncs.h file that you can find here : C:\WINCE600\OSDesigns\Mini2440\Mini2440\Wince600\Mini2440_ARMV4I\cesysgen\oak\in c under wince 6.0 I don't know where it is under CE 5.0, you have to find it by yourself domodom
domdom u are great thanks very very thanks.................... for helping me at last i got the output............................................... can u give me ur phonenumber i have to speak with u......... love u .......................
Congratulations !! It's funny the pleasure we can sometimes feel just by turning on a led !! ;o) I rememeber the night 20 years ago, when I succeeded to light on a led by pushing a button that was triggering a interrupt in a 8051... If you want to directly contact me, you can do it via my website. Best regards domodom PS : a french expression : plus ça rate, plus ç a de chances de réussir -> the more it fails, the more it has chance to succeed
Hey domdom ya ya ayae hurrah thanku...................... he he he ha ha ha ha thanks a lot.................
hi domdom what am i doin here volatile IOPreg *s2440IOP = (IOPreg *)IOP_BASE; pls tell me am i declaring pointer *s2440IOP same as iopreg then what is this (IOPreg *)IOP_BASE; explanation please
s2440IOP is the name of your variable. IOPreg* is the type (= a pointer on a IOPreg object) volatile is a compiler directive that ask him to calculate the variable each time you use it. IOP_BASE is the adress of your registers, you want s2440IOP to point on this address, it is defined in a .h file included in your project, with a line like this one : #define IOP_BASE 0x12345678 Before compilation, the precompiler will replace, in your source code, IOP_BASE by 0x12345678 If you write : volatile IOPreg* s2440IOP = IOP_BASE; after precompiler, you will have volatile IOPreg* s2440IOP = 0X12345678 you will have a compiler error, because the type of the terms each side of the = sign are not the same (a pointer on an object at left, a number at right) That's why you have to make a cast operation to transform the number in a pointer on the same object : volatile IOPreg* s2440IOP = (IOPreg*)IOP_BASE; Is it clear ? domodom
Hi domdom
everything is clear.
one silly question
in structure concept what we will do is
struct domdom
int hello;
}a,*ptr;
then we will access it by a.hello=35;
then we wil access hello by a pointer we will use arrow sign like this
ptr->hello=35;
but here my doubt is
in header
typedef struct
uint rgpdat
uint sddd;
uint xxxx;
uint wwww;
}IOPreg;
so here IOPreg is not a pointer and u said s2440IOP is the name of your
variable.
so we are not using any pointer here then what is the need of arrow sign
s2440IOP->rGPBCON here......pls dont kill me............................
thanks domdom...
yes, s2440IOP is a pointer, you declare it like this : IOPreg *s2440IOP; If you write IOPreg s2440IOP; you access the member of the structure with s2440IOP.rgpdat but if you write IOPreg* s2440IOP; you access the member of the structure with s2440IOP->rgpdat domodom
but domdom in gpio.cpp we have declared like this right IOPreg *s2440IOP not like this IOPreg* s2440IOP; which is correct a confusion here....
ok domdom thank you..see domdom u are the only one helping in this forum. why people's are greedy? like u i will also help every person i love ur true heart...truly byeeeeeeeeeeeee thankuuuuuuuuu uuuuuuuuu uuuuuuuuuuuuuuuuu uuuuuuuuuuuuuu uuuuuuuuuuuuu
No, i'm not the only one. Each people answer if he has time and if he can help. I don't reply when I don't know the answer (you won't see me replying in the linux section for example... ;o) domodom
hi domdom,
whats happening in ce.iam very confused i tryed to write a serial port
communication for transmitting char "a" by accesing the registers.
in the data sheet they have given some registers to set like pic
microcontrollers. i did all and its working fine
s2440IOP->rUBRDIV = 21;//baudrate 115200 kbs..
s2440IOP->rULCON =0x03;....
s2440IOP->rUCON =0x4C04;bla bla
s2440IOP1->rUCON=0x8000;
s2440IOP2-> rGPHCON = s2440IOP2->rGPHCON & ~(3<<16); //GPH8(UEXTCLK) input
dely(1); // about 100us
s2440IOP2->rGPHCON = s2440IOP2->rGPHCON & ~(3<<16) | (1<<17); GPH8(UEXTCLK)
UEXTCLK
while(i)
MessageBox (NULL, TEXT ("send a"), TEXT ("SERIAL"), MB_OK);
s2440IOP->rUTXH='a';
i++;
if(i==4)
break;
but after that i checked by commenting each of the line like this
//s2440IOP->rUBRDIV = 21;
//s2440IOP->rULCON =0x03;
//s2440IOP->rUCON =0x4C04;
//s2440IOP1->rUCON=0x8000;
//s2440IOP2-> rGPHCON = s2440IOP2->rGPHCON & ~(3<<16); //GPH8(UEXTCLK)
input
//dely(1); // about 100us
//s2440IOP2->rGPHCON = s2440IOP2->rGPHCON & ~(3<<16) | (1<<17);
//GPH8(UEXTCLK) UEXTCLK
while(i)
i++;
if(i==4)
break;
and i came to know only one line is enough
how it is possible....
any ideas .or accessing only one register is enough domdom
hi domdom, anyway i got the output for serial txion and reception using registers. my next project is rfid attendance system with wince for that how can i fetch wince time using evc++,then how can i write datas to a notepad or to a excel sheet. can u help me regarding to this..... godnight bye----pls see the above thread also. domdom.......i want to say one thing now iam feeling very strong in my company because of u thanks for the help
Hi domdom
iam doing a rfid project now.
but a problem while displaying a dialog box.iam using a infinite loop
to check for rfid card input.so iam sending value char->"C" from the
computer serial port to mini 2440.it is correctly matching if i send the
correct word.but at the first time only dialog box is opening and
displaying my name selva and after that when i click ok it is closed upto
this my program is working fine.after the first time if i send the
character the dialog box is closing very fast.for that i have tryed full
night to make the dialog box stable but i cant. can u give me a solution
while(1)
if(s2440IOP->rUTRSTAT==0x7)//to check wheaathet character is rxed only read
is allowed for this reg
if(s2440IOP->rURXH=='c')//checking for a
CDateandtimeDlg dlg;
m_pMainWnd = &dlg;
int nResponse = dlg.DoModal();
thanks
domdom
Hello, Sorry for my late reply, I have a lot of work this week. For your problem with the registers that don't seem to have to be configured, if launch an application that configure the registers, after the end of your application, the registers keep their configuration value. Then, if you start another application that use the serial port without configure these registers, it will work. For you second problem, I would need your source code to understand what is wrong. But I don't believe to have time to have a look on it before next week. domodom
ok domdom, Thanks for ur reply.......if u have time pls tell me. i will provide my source code thanks for ur reply.
Hi domdom,
pls help domdom sorry to disturb u one small problem pls help me
domdom silly thing for u'
while(1)
m_time = CTime::GetCurrentTime();
and iam using this function to get time and display it in timer picker
control....
when iam using an infinite loop like above its not working..
while(1)
break;
but if i use break after it ,it is working fine
how can i make it to work in infinite loop help pls domdom
Selva, do not get angry with what I'm going to say, but there is no need to insist in this way in the forum ... it's a little annoying for the rest. when someone, domodom or some other person, can will answer to your doubts. Regards, and good luck with your project. Fernando
thanks fernando,
u are right but domdom is the only person right now helping
me.so i did like that.sorry fernando i won't repeat it.
thanks for ur care.........
hi fernando,
i think u also working with serial port.if u are having any problem
with serial i can help u ....
Thanks selva, and I'm glad you didn't get angry with my comments. Yes, I'm working with the serial port, but no problem with it, I am handling it ok. Thanks anyway for your consideration. Sadly I cant help you much with your needs, because I never used Visual C, only C for DOS or microcontrollers... someday I hope I can learn Visual C (just need time + good tutorial), because I know is a lot much powerfull than Visual Basic. But for the moment.. I'm sticking to what I'm used to :) Fernando
Hello. How do i found the pkfuncs.h?, I have not been able to find it, appreciate if someone help me find it. My mail is albusve@hotmail.com.
